My first CTD, but its an oddball
Howdy yall!
I recently purchased a '91 W250 that is said to have 95 12-V in it. Ive been around gear heads all my life, but the Cummins and (relatively) old truck are a new thing for me. I was hoping, with the pictures supplied, a few of yall could take a look and tell me what i have for sure.
AND, according to my brother in law, this toggle turns on the fuel pump...? Im lead to believe there is no electric fuel pump used by the 12-V
I haven't even seen the truck yet as I bought it while I was deployed, I just hope someone could shed some light on what the previous owners did to my rig. Also any suggestions will not be taken lightly
Finally, they put a Lund moonvisor on it that looks awful. You need to remove it immediately and send it to me.
--Eric
The truck is a '91.5, the firewall mounted regulator is original. I see no reason to doubt that the engine is out of a '95. Looks like a fun truck with lots of potential.
Sent from my Paranoid Android HD2 using Tapatalk 2.
It has 1st gen intercooler tubes and boots, so it could be a p-7100 conversion on the original engine, i can't tell if the engine is 1st gen or 2nd by looking at the pics, but i will beet Faith can.
if your going to do some performance mods i would move the EGT probe to the manifold instead of the down pipe.
it looks like a pretty good ol-truck though
Dar
Dar
What I see:
2nd gen engine with 1st gen intercooler conversion, along with the stock H1C 1st gen 'charger.
I suspect it is 100% 2nd gen, BESIDES the intercooler pieces and turbo, because it also has the wrong fan support assembly and the thermostat housing I also recognize as 2nd gen.
You'll need to get the correct fan support before you can run the OEM shroud on there, BTW.
It also looks to me like they put the grid heater on backwards, then lengthened up the wires, instead of fixing it right.
Mark.
Mark.
Wowsers, thanks for throwin all the info at me guys! I wont be home for 2 more weeks but ill have a whole month of nothin to do but work on her, all this helps more than yall know! It did come with the front driveshaft but i hadta hunt down one of those conversion u-joints so my uncle could put it in (diff end was 2 diff size caps ends i guess) A part from all the little whips yall've pointed out, Im plannin on free pump mods, MAYBE fuel plate, 2nd gen seats, big-ol front bumper, build that air cleaner a proper box, leaf-shackle flip if i feel froggy enough, etc.
Now, 2 questions:
-Are the fan shroud/support bracket year/motor/truck specific or any 1st gen diesel hardware should work?
-Whats the easiest way to see what tranny is hooked up in their? Id have to ask my sister to look for me SO itd have to be a simple means
Now, 2 questions:
On the rear suspension not only does it have an extra rear block stacked in but 3 leafs as well. The original config is ends at the fat overload leaf. The ones below that may or may not be bolted to the rest of the (bastard)pack.
If you take them out and put it back to stock like you should if this is going to be anything other than a play truck that doesn't haul/tow then it will be way high in the front. Curious what front leaf setup is in there. Hopefully no blocks up front.?! The front already looks VERY lifted. I'm not sure the stock driveshaft would work, I see that you have a separate d shaft to bolt in. Be careful and flex it out and make sure the CV will bend that much at full droop...
looks like it started life as a non intercooled! someone installed a intercooled radiator and used a bunch of flat washers to hold it to the non intercooled core support ,
Your truck brings to mind the Jonny cash song ONE PIECE AT A TIME! you need a skinny pedal too
