My 89 Is sooo quiet
My 89 Is sooo quiet
My 89 d250 is practically silent compared to the truck in my signature. Im not talking about exhaust noise either. Is this normal? Its an awesome truck for 400 dollars. I got my column together and working. The only thing i need is new upholstery and the shifter parts. unfortunately, i found a dead rat under the seat. it managed to eat away a good bit of stuff. My truck has what appears to be a factory high idle control on the pedal, a different throttle bracket, and a different vacuum pump among other things.
The hand throttle huh. Cool. Let me know if you want to give that away... Keep your eyes peeled for the newer style vacuum pump, cheaper and better upgrade than fixing them if they crap on you.
Or maybe, you're just crazy...
It's probably timed stock, and the valve lash might be a little tight. Makes 'em real quiet.
I like the old style vacuum pumps, they work pretty well even if you lose one diaphragm. Jim Lane wrote a nice "how-to" on working on them, it's in the sticky.
Paint it with black primer, leave the upholstery, make a shifter out of rebar and an 8 ball, and call it a "rat rod".
Werd on everything he said,
The vac. pump on our 91 quit and it just had bad brakes until it was warmed uop, not too hard to live with my dad said, my mom hated it though
the rebar shifter would be swweeeeeet.
im actually toying with doing a rat fink lime green with pink flames scheme. it is timed stock and is quiet at any rpm. the factory stereo in this truck is also way better than mine.
flat black truck (roll on ) with red rims...
Oh my gosh that would be sooo cool. and old school
If your not gonna tow with it, cut the front coils down and remove some rear leaves and make it lower like SkinnyBTN's truck.
Your so lucky, $400
Your so lucky, $400
slimerept
16
11-23-2008 03:53 PM
torkmnstr
02-13-2008 01:52 PM
