My 2wd frame just got an upgrade....
Old 11-09-2009 | 05:24 PM
ADMOPARMAN's Avatar
I think that drilling the holes for the rear hangers was the hard part. Now all I have to do is bolt the front hangers on and swap crossmemebers.
Old 11-09-2009 | 09:29 PM
bigredbrick's Avatar
That's something I'm gonna be doing!
Old 11-09-2009 | 09:47 PM
TIMMY22's Avatar
[IMG][/IMG]
Old 11-09-2009 | 11:35 PM
NO_SPRK's Avatar
sweet! POR 15? that stuff is nasty. never comes off
Old 11-10-2009 | 08:24 AM
Twisted Inc.'s Avatar
i'll second that POR15 is good stuff, here's a question is the 2wd rear spring hangers the same as 4wd? as far as hieght?
Old 11-10-2009 | 08:41 AM
Trebor's Avatar
POR 15 works great when properly applied. If you fail to use the phosphoric acid based rust neutralizer cleaner and properly rinse it will most likely peel.
Old 11-10-2009 | 08:44 AM
ADMOPARMAN's Avatar
Yeah the rear spring hangers are the same... There are 2 different sizes of rear blocks that the 4X4's use to gain the lift.
Old 11-10-2009 | 08:12 PM
Bogie's Avatar
Front shackle mount upgrade
Old 11-10-2009 | 08:29 PM
ADMOPARMAN's Avatar
Yeah I saw those but this crew cab truck isn't even supposed to be happening so I'm on a shoe string budget. (according to my wife )
Old 11-10-2009 | 08:37 PM
TIMMY22's Avatar
Chassis saver
Cleaned it good with wax and grease remover prior to application.
Old 11-10-2009 | 09:20 PM
Hey ADMOPARMAN, if not on your to-do list add reinforcement/brace frame at steering box. That's another thing I have to do.
Old 11-10-2009 | 09:33 PM
ADMOPARMAN's Avatar
I was looking at that when I pulled the gear bracket off the W200.. Anyone have any ideas on the best way to brace it??
Old 11-10-2009 | 10:08 PM
http://ramchargercentral.com/index.php?topic=52254.0
One way to do it. I know that my '93 Club has a lot of frame movement in the steering box area - frame rivets may be loose in their holes?
Old 11-10-2009 | 10:20 PM
http://www.dodgeconnection.com/catal...66/4541374.htm
And this is a simpler way but not as strong. my understanding is that this brace was available on some Ramchargers.
Old 11-10-2009 | 10:24 PM
Bogie's Avatar
I know that situation Just good to know about My Crew is a gasser and I have a set for it as I know the stock ones are shot and with the added weight of a Cummins I imagine there under more strain.
