Multiple codes
Multiple codes
Once in a while the truck starts throwing a number of codes and it is usually all the same ones 24, 33, 41 and 45. The PO replaced the battery and the alternator. When the codes sre on it is charging at 9 or so and when there are no codes (no check engine light on) it charges at 14 or so. Any thoughts?
Scott
Scott
Sounds like the connector on the PCM is cruddy (or the PCM is flaking out). Try unplugging and reconnecting the PCM a few times, then spray the connections with electrical contact cleaner, let it dry, hook it back up and see how it goes.
I will try that, I was wondering since they are all open relays and the field circuit if they could be connected or tied together with something else.
JOHNNY_77_
09-30-2011 07:28 AM
cincydiesel
09-21-2011 10:21 PM
OCMerrill
11-18-2009 09:40 AM
User Name:
16
09-18-2009 06:25 PM
rip 112
19
06-17-2008 09:38 AM
