motor trans swap...94 to 93
Old 02-20-2009 | 07:36 AM
joker834's Avatar
motor trans swap...94 into my 93
Ok so my trans is shot and I have access to a wrecked 94 4wd automatic single cab dually with 51,000 miles that I can purchase VERY reasonably.
I wanted to do a p-pump and trans upgrade eventually so this seems to be a 2 birds 1 stone situation. Plus my current engine is at 275k so backing up to 51k would be nice.
How difficult will it be to swap the entire driveline into my 93?
will everything I will need be on the 94?
Also what about performance mods that will work from the 93 to the 94?
Old 02-20-2009 | 10:45 AM
DNRCustoms's Avatar
Run it, probably be able to swap it all but the front axle pretty easily... I would stick with the 205 case thats in your truck now though.. I think they switched t-cases in 94 to a chain drive case... But, the motor, trans and rear axle would be a nice addition if the price is right...
Are you planning on using the motor out of the 94 too.?? I would be doing the 2nd gen intercooler swap if it is good out of it too... Lots of good parts can be had from the 94..
Good luck and keep us posted!!
Old 02-20-2009 | 11:08 AM
Field_boss_cb's Avatar
I think you would use the transfer case that is in your truck now, the reason being the driveshaft for the front-drive axle is on the left side of the 1994 and up trucks and on the 1993 and back are on the right side of the truck. It maybe that the transfer case could be unbolted and turned-over to the right side, I don't know. The frame needs to be bent-up at the point where the starter is, keeping it from banging the frame. May need to changed the location of the pivot point for the gear shift linkage going from the frame to transmission, some have got by not changing the pivot point.
Old 02-20-2009 | 11:27 AM
dstad's Avatar
id say go for it. come on you would be getting a pupmped 1st gen.
Old 02-20-2009 | 01:30 PM
joker834's Avatar
I would like to do the full swap (minus the t-case if it wont work) just really want to know what I am getting into on a motor + trans swap.
Old 02-21-2009 | 07:17 AM
joker834's Avatar
nobodys done an engine/tranny swap together?
Old 02-21-2009 | 09:06 AM
DNRCustoms's Avatar
Im guesing you'll be the first!!! you buy that stuff yet??
Old 02-21-2009 | 09:12 AM
joker834's Avatar
Made a deal with the fella this morning and going to pick the truck up on Monday.
The only things gone from the wreck are the ic and radiator. All the piping is still in place but the ic is gone.
Old 02-21-2009 | 12:24 PM
Try to use the PCM off the 2nd gen, that way you will get automatic operation of the lockup converter. Gonna take a little bit of wiring but it can be made to work.
Old 02-22-2009 | 07:19 PM
joker834's Avatar
wanna do you know where i might look for info on doing that?
Old 02-22-2009 | 08:45 PM
bullfrog5.9's Avatar
here at an big rig junk yard the guy sells p pumped cummins and an allion 545 together for $2500 id like to do that
my uncle has a p pumped 1st gen reg cab with the 727trans behind it and the trans case i not sure what one is there
but go for the swap it be easy to do
Old 02-23-2009 | 05:45 PM
Good wiring diagrams for both trucks are all you need. The factory service manuals have the best diagrams.
Old 02-23-2009 | 05:50 PM
Checkmate's Avatar
Is the frame messed up on the 94 ? If not, do a body swap.
Old 02-23-2009 | 05:54 PM
joker834's Avatar
The frame is messed up and it's a single cab and mines an extended cab.
badzj999
08-20-2010 05:17 PM
Stroked-Z
20
03-03-2010 04:08 PM
ryan10
08-10-2007 09:38 PM
Common
05-09-2007 12:11 AM
coupdetat
02-17-2007 12:52 AM
Quick Reply: motor trans swap...94 to 93
