Missing one ball...
Old 01-25-2006, 04:25 PM
That's entirely possible. Next time you start the truck cold, unplug the KSB while it's running badly and see if it starts running even worse.
Old 01-25-2006, 04:39 PM
kc8ksg's Avatar
Will do, if my KSB is bad, is it something that has to be fixed and will hurt something if I don't? Or will it be okay just to run it the way I have been, and where do I get one, and how much roughly?
Thanks
Chris
Old 01-25-2006, 04:48 PM
Won't hurt anything. Just makes smoke. If the problem is wiring or the switch, that will be cheap. The solenoid is expensive. There are several good threads on KSB diagnostics so I won't get into that here.
Old 01-25-2006, 06:15 PM
ouchman's Avatar
I have done a lot of searching and I still can't sem to find part numbers for:
1) KSB or Solenoid
2) Temperature sensor (for KSB)
help! thanks.
Old 01-25-2006, 06:37 PM
You didn't look hard enough.
https://www.dieseltruckresource.com/...2&postcount=12
I dunno on the solenoid. Those rarely go out and they are very easy to test.
Old 01-25-2006, 07:21 PM
bgilbert's Avatar
Guys move on to something else. Who cares about the KSB unless you are on a dyno and are looking for more total advance for big hp #'s. It's not necessary to start the truck, strictly an emissions device.
Old 01-25-2006, 08:05 PM
Patron Saint of 1st gens
Bushy's Avatar
I'm gonna go with Bill on this one....the KSB has a practical use in terms of cold start/emissions issues for sure, but, it is not really a full time factor when it comes to daily driving....at least for most
BTW, as I understand it, the KSB, when activated, closes off a passage inside the pump and the result is a near doubling of the internal (supply side) pressure, which in turn, effects the timing of the pump getting rid of or reducing smoke.
pb...
Wulzcat
12-19-2009 05:15 PM
wcbcruzer
22
04-30-2008 06:58 PM
welndmn
01-31-2007 07:59 PM
Quick Reply: Missing one ball...
