Mind Boggling Question
I'm trying to put A/C in my Power Wagon. It has a first gen diesel with the A/C compressor.
In effort to match the condensor with the A/C compressor I need to know how many cubic inches the pump puts out per revolution.
Thanks,
Mike
Thanks,
Mike
Thanks for the reply Buddy, I'm in the process of making the old power wagon an extended cab so the A/C needs to work at peak to keep the large cab cool.
I've been doing lots of reading about A/C units and it appears the condensor is the most important part of the unit. With 2 decades of improvements there switching to thin flat tube style condensors so more area to cool the refridgerant. While the round tube cond. only the gas touching the outer part of the tube is getting cooled to liquid. While the gas in the middle of the tube is not being cooled and turned back to liquid.
Since this is going to be a pain in the edit to put A/C in it I want to do the best job I can. So thats why I need to find out the cubic inches per revolution the pump puts out so I can get the matching condensor.
Anybody?
Anybody?
You might just want to work your answer out with a different formula... (how much space do I have/ how big of a condenser will fit in that space) You cant hurt your a/c performance by going to big.
I don't know the answer to your question but that is one cool project you are undertaking
love those old Power Wagons and have always wondered why they were gassers
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
If so, you can get detailed info by contacting them.
http://www.sanden.com/index.php?id=AAUYOIFBS
Also, some specifics here:
http://www.heco.net/maincat/compressors.pdf
Trendz, I got lots of room up front for a condensor but not much room under the dash for the unit since the engine sits 9" back into the cab. The helpful link Patdaly posted says the condensor needs to match the pump. I'll measure my pump to find out which one I have then get the correct size condensor. Thanks Pat!!!
Sortie, thanks for the positve reply! This is my 3rd time rebuilding this old truck. The 1rst time I did a 50/50 job. 2nd time I did a pretty good job. Now this time I'm trying to do a great job so I don't have to do it again.
Sanden's are easy to decipher,
Sanden SD709 =
SD (Sanden Wobble Plate Piston Type Compressor)
7 (7 Cylinders)
09 (approximate Cubic Inches per revolution)
More accurately,
9.5 cubic inch
154.5 cc displacement
From all of the many trips I have taken down the information superhighway I have yet to find much techinical data on the old C-171 compressor but I have been told the C171 compressor is.
170cc displacement.
Nothing says you have to have the condenser in front of the radiator or in front of the truck for that matter, I have built my own shroud and added electric condensing fans to a modified condenser and stuck it in the rear of a vehicle.
You can stick a remote condenser anywhere.
http://www.nostalgicairparts.com/air...-shroud-33.php
Download this PDF file, I have had this for a few years and starting around page-6 there is a lot of of good information and guidelines to build a system and live by.
Download these files and keep them in a folder named Useful AC Information
http://www.sanden.com/originals/imag...uide_Rev.2.pdf
Also 7.3 Pressure or Pumping Test on page-14 is a good test I use to check for a weak or failing compressor.
I also use this chart for determining the correct amount of oil to add to a new compressor.
http://www.rtitech.com/downloads/New...Compressor.pdf
The correct amount of oil is very important.
Jim
Sanden SD709 =
7 (7 Cylinders)
More accurately,
9.5 cubic inch
170cc displacement.
Jim
Jim, I've gone through all the helpful info you posted. Lots of good stuff. Thanks for taking the time to post it!
Since most like pictures of this old truck here are a couple more.
keep the pics coming, Mike!
that is one Mean Machine with the CTD in it, and I bet you can actually hear your tunes over its roar with that speaker setup!
the nicest, most knowledgeable comments I get on my 1st gen are at big-rig truck stops...
Sortie, I hope to keep this truck till I die. The woman is not to happy about my way of thinking. But I tell her we paid $45,000 for our 4x4 Duramax and I ain't going to keep buying new trucks that I can't work on. This my way of looking at it, "Keep it simple stupid"
With the old power wagon having F-350 cross over steering and hydro booster along with 4 wheel disc brakes. It drives strait and has good brakes.
Best of all it's got a CTD with 7.3 F-350 cooling system so it has no heating issues when towing on hot summer days.
Cool rig
What dies the pto run?...Mark
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
Mike, women are NEVER happy with what we're spending on our rigs
that's why I buy mine a new SUV every few years, so I can compare the payment on the note to my maintenance/improvement costs
fortunately my daughter loves my rig so I don't care what wifey and her daughters think of it
