Methanol/water injection kit
Old 04-12-2012 | 11:57 PM
bwest1107's Avatar
Is anyone running the snow performance methanol/water injection kit? and if so does it really increase your MPG??? And what kinda power gains are you getting with it?
Old 04-13-2012 | 12:36 AM
u.s mma's Avatar
i don't have the mileage max or whatever its called, just the stage 3 , can't remember which nozzle is plumbed off hand. I think its cool, i really notice the power when towing or hauling a cord of green birch or the like. i get a good 200-300 degree reduction in temps.
Old 04-13-2012 | 10:39 AM
rebal's Avatar
havnt seen any temp reduction but easy 70 hp increase seen on the dyno
Old 04-13-2012 | 01:41 PM
Greed 93's Avatar
Small mpg increase for me but you can really feel the power.
Old 04-13-2012 | 02:49 PM
bwest1107's Avatar
where did yall buy it at? was it pretty easy to install?
Old 04-13-2012 | 09:35 PM
u.s mma's Avatar
i got my kit from j&h in redding. very easy to install, make sure you put the pump close to the tank.
Old 04-13-2012 | 11:58 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
if you have lots of fuel (injectors, pump work) you may not see any power increase. It seems to make power when its being used as more fuel. That's what keeps me from getting the kit.
Old 04-14-2012 | 06:56 AM
Bob Beauchaine's Avatar
Look at my sig and you can see the difference between RWHP on #2 and with w/m. As said before power increase varies with each vehicle. My w/m is a Snow kit with the older Stage 3 controller. I'm running a .375 and a .675 nozzle. I just use washer fluid unless I am on a dyno then I use a 49/51 mix.
Bob
JJCAMARO1952000
17
05-05-2009 08:53 AM
n0ne
46
08-03-2006 04:05 PM
Lambo
03-25-2004 08:41 AM
mcevins
01-13-2004 12:30 PM
Jim Fulmer
11-22-2003 09:21 PM
