Metal Shavings in Trans Pan
Picked up my 47rh this weekend and found this in the pan:
The brown speck in the pan fell in there after having it pulled. The shavings must be aluminum, they don't stick to a magnet. There was no more on the other side of the filter or in the valve body anywhere.
The trans was rebuilt 25,000 miles ago. How concerned should i be about this? I would think it will only get worse
Same here. Every auto pan I pull has junk in it. Of course if you take it to a tranny shop they will say you need a full rebuild. I, of course am too cheap to let some ape that I dont know tear into my junk. Therefor, I throw shift kits in all my junk and let er rip. Only let me down once so far, and that was throwing a under rated trans behind the engine in my car. Shoulda known better.
How was it in the previous vehicle? Did you buy it from a wrecker? If so, they should have some sort of warranty on the parts they sell...
Probably coming from the converter. Some fine sparkles are normal but the bigger chunks usually means conveter. Did you flush the coolers both directions before installing the new trans? Lots of crap hides in there.
I wouldn't be too concerned about the metal, that seems to be normal with aluminum plantaries.
The grey stuff is clutch material. Seems to be alot jammed in there, but I've seen worse.
Can't really tell if its from the converter or one of the clutches in the trans. Try to take a look up in the OD unit, if you see alot of clutch material up in there is probably the converter clutch.
Check the trans input shaft endplay before you take it apart. Shoot for .030" to .060". If its over .090" its excessive and needs to be addressed.
He just bought the trans from another member here. Going to install it in his 1st gen. Doesn't want to put a trans in thats on the verge of going.
I did look look and turn around the converter a little and now that i think of it there was some in there. I guess thats good news for me beings the converter is on it's way to goerend.
kinda, i sent the cores in today to avoid the core charges. I am getting goerend's triple disk converter (forget the stall speeds lost the paper ) valve body with lock up in all forward gears, and a billet lever, strap and anchor. by the end of the summer i hope to have a billet input to take advantage of the lock up on all forward gears.
Oh...man I am all giddy and It's not even my stuff... I definately want an in depth report on how it performs... So how much for the stuff you bought, I want to do the same thing.. Lock up in all foward gears, with the Billet input will you be able to keep it locked while shifting under pwr?? If you want you can pm me the $$ if you want..
