mechanical water temp guage
Where is the best place to put the sender for my mechanical water temp guage on my 89 ctd? i currently have it in the top of the head that takes a 3/8 drive to get out but my guage is not giving me any readings. I need help please
While on the subject, where are some better options to locate a mechanical sender ??
One reason for having the gauge in the first place is to alert one to a loss of coolant; but when the coolant level drops the least little bit, a sender in that location is left high and dry and just drops to ZERO, regardless of engine temp.
I would like to plumb mine into somewhere that is more apt to stay submerged.
what size is that dang big hole is it a standard size like for a gassers temp gauge,or is there an adapter.or can i put it at the allen headed plug at the water neck?
wheres a good place to put one cause this new motor will have all mechanical gauges.as for oil pressure i figured id use the factory sending unit plug after i take out the plug.am i on the right track
I also would like more info. I am going to be installing a isspro water temp but would also like the factory gauge to work. I just spent 70 bucks on a new sender for the factory gauge last summer. I , for the life of me can not remember where my old 89's used to be hooked up. It was twords the front of the engine somewhere. Just cant picture it.
