mechanical oil pressure gauge
Old 02-19-2007 | 06:55 PM
ryan10's Avatar
I have a sunpro mechanical oil pressure gauge, its a 0-100 psi, it was origionally going to go on my other truck, but since my stock gauge sucks, i was wondering if it would work on my 91 cummins? If so, how do i install it? Does it just install in place of the old electric sending unit? When i pull the old on out, will oil come out of the hole?
Old 02-19-2007 | 07:08 PM
bgilbert's Avatar
Passenger side of engine, oil filter adaptor/cooler. On top of it there's a 1/8npt pipe plug. Remove, thread in your fitting and tubing. You don't mess with the driverside OEM sending unit.
Old 02-19-2007 | 07:09 PM
ryan10's Avatar
Ok, where exactly is this located? Right above my oil filter, there is a small bolt. Is this it? if so, do i just remove that, and thread in the 1/8" tap for the oil pressure line?
Old 02-19-2007 | 07:10 PM
bgilbert's Avatar
Ever changed your oil filter? On top of that.
Old 02-19-2007 | 08:28 PM
G1625S's Avatar
My tired old engine pegs a 100psi gauge when cold...might look for something that goes higher.
Old 02-19-2007 | 09:11 PM
ryan10's Avatar
i already have the 100 psi gauge, so ill use that for now.
Old 02-19-2007 | 09:19 PM
ryan10's Avatar
Also, what is the best way to hook up the light in the gauge?
Jake9612valve
09-14-2011 04:22 PM
grim
08-07-2010 11:46 AM
Micaiahfied
07-25-2006 11:02 PM
firesafety3
06-17-2006 08:02 AM
Bluedeviltorque
10-02-2004 12:06 AM
