Max safe boost in NON IC truck???
I am curious what you all know from expirence, or what you thing what a "safe" boost level would be on a non ic rig?
Peter.
Peter.
If you have the original nonIC head gasket, I'd stay under 30psi and 1.5mm timing for longterm reliability. They started using marine grade gaskets with the intercooled engines. I agree for the intercooled/ later style gaskets- over 40 has me questioning my NEED for this kind of pressure.
Daniel
Daniel
Yea blew the stock head gasket when i got the new turbo upgrade, 316K miles on truck though.
Dave and i installed a new .5mm thicker one, Runs better than the day i got it!
Peter/
Peter/
I've repeatedly pegged my 40psi gauge, but with my recent mods to the 12cm housing, the wastegate will hold what little fuel I've got to a comfortable 32psi--and I've pulled my timing back close to stock.
Sooo your mega intercooler has over comp so your timing don't have to any more.
Flash.
I've had mine tuned up towards 38 psi without problems. I am running a Fel-Pro headgasket in mine. I am not sure if that is any better than stock or not.
-Steve
-Steve
From pictures I've seen, it (Felpro) isnt as good, but if it works, run it. Most parts store aftermarket stuff is a step down from OEM; most aftermarket from the likes of PDR, II, et al, is much better than OEM.
DP
DP
belfert
09-09-2004 03:23 PM
Gypsyman
07-28-2004 12:11 PM
wannadiesel
07-17-2004 06:12 PM
Diesel Dave
07-09-2003 06:54 AM
