Max rpm before valve/studs upgrade
You start heading above 4000 you're gonna need the 60lb valve springs.
BC did a great (as always) write-up on the valve spring up grade. Look under performance in the sticky.
Head studs are usually determined by boost pressure, not necessarily RPM. According to a Cummins engineer I spoke with, mechanical damage on a stock engine occurs starting about 5,000 RPM.
I would agree with that. I am at 40PSI and on 3,200 rpm blasts I lose a fair amount of antifreeze down the side of the block. Waiting for better weather (and a bottoming tap) to put my ARP's in.
77machomopar
11-30-2009 11:55 PM
12valve
03-11-2008 10:57 AM
Bobcat698
11-24-2005 12:49 PM
fishin fever
02-22-2004 08:32 PM
