to many lights?
to many lights?
So I finally got this ol truck put back together the other day after redoing the electrical from bumper to bumper. The p.o. had it in the worst mess I've ever seen. It was my first time tackling something like this, and there's no way I could have done it without this forum. Anyway, I pulled the light switch out for a try and no smoke, no fires. That made me happy. All the lights worked except two running lights on the flatbed, and one cab light. I didn't have replacements at the time, so I checked them with a test light and confirmed that I just needed a couple lights/ lightbulbs. Cool! I was excited and took it for a drive. High beam, low beam, brakes, and blinkers all worked as they should. Great. So yesterday I got around to replacing the lights and bulbs that weren't working. When finished, I pulled the light switch and every single light came on.... for a minute. All running lights went out. Checked fuse, and it's blown. Looks to be about ten years old anyway so no biggie. Replace fuse and a couple minutes later it blows. All out of 20a so I throw in a 30a. Same result. Today I spent all day checking and searching for a problem, and I can't find one. Why was my test drive with a couple less running lights ok? Could it be that there is no problem, and there's just to many lights on one fuse? How many is to many? I'd appreciate any thoughts. Thanks guys.
That or a short somewhere. The fuse is there to protect the wires. You should never use a bigger rated fuse.
Check current draw as well. You may have a bad switch.
If you relay your headlights, that will lessen the current draw through the switch
IF I was doing this I'd undo the lights that were not working and see what happens before I start hunting buggers. They worked ok the you fixed the 2/3 lights and now problems happen. If that works hook up one light at a time and see what happens. Good luck!!
Good luck, Tony
Location: In Oroville, Ca., same house for past 46 yrs!
Yep, sounds like the two or three you had originally that didnt work are the reason it's blowing fuses now. look there.
Maybe when you put on the lights, the rivewt or screws are touching a hot terminal inside the light.
While we're on the subject though, how much power can you run through one spot before you would build a relay harness, or a power distribution center of some sort?
If there are several extra lights wired into the circuit, I would strongly consider powering them through a relay, knowing that the factory lights are pretty much all the load the switch can handle.
Txwelder
09-27-2007 07:48 PM
