Manual hand pump will not prime fuel system for me
Old 08-09-2013, 06:21 PM
DOZENVALVE's Avatar
Cranking with throttle in any position for about 15-20 seconds....no fire, not even 1 sputter
Old 08-09-2013, 06:29 PM
93-12Smoke's Avatar
Dumb question but ya did tighten the injectors back down right
Old 08-09-2013, 06:58 PM
93-12Smoke's Avatar
Injector lines i should say
DOZENVALVE's Avatar
Well the injectors themselves never came out but as far as where the fuel line meets the injector, I cracked each one separately about a half turn until it was gushing fuel, then tightened it snugly and moved on to the net. I was hoping to fire t up and then purge some more air while it was running from each injector individually. Then shut it off and torque the lines to spec.
Was just trying to get a 12v reading from the fuel shut-off solenoid and I couldn't. Although I don't see where the power source is for those two little wires. It just goes up to a plug that plugs into the manifold.. So I'm still at a loss. Haha. This is super gay.
Old 08-09-2013, 07:02 PM
maybe368's Avatar
Run a jumper cable from the battery to the fss. But, it seems that if you are getting fuel to the injectors, the fss is working...Mark
Old 08-09-2013, 07:03 PM
93-12Smoke's Avatar
Swap the ksb plug and the fss plug.
Old 08-09-2013, 07:04 PM
93-12Smoke's Avatar
With the key in the run position you should have 12v to the fss.
Old 08-09-2013, 07:14 PM
DOZENVALVE's Avatar
Okay what does KSB stand for? I'll try it nd be right back!
Old 08-09-2013, 07:18 PM
93-12Smoke's Avatar
It's a fancy word for the cold start advance.
Old 08-09-2013, 07:24 PM
DOZENVALVE's Avatar
copy that.
it worked! all i needed was some plug switching.... but this has led me to yet another dilemma. it will fire but immediately die. and if i use throttle it will just sputter sputter sputter sputter until i let off the key..
throttle index?
Old 08-09-2013, 07:26 PM
DOZENVALVE's Avatar
Once you confirm that is the problem you will just have to adjust it one click at a time till ya get it back on spot. If it's a long way out then you can jump a couple clicks.
where do i adjust these "clicks" and what do you mean by them... are we talking on the linkage somewhere or actually on the throttle lever?
Old 08-09-2013, 07:31 PM
93-12Smoke's Avatar
The throttle lever splines onto the throttle shaft going down into the pump top. By click i mean you adjust the splines one way or the other
Old 08-09-2013, 07:36 PM
DOZENVALVE's Avatar
ill go see what i can do. thanks for all your help today!
Old 08-09-2013, 07:40 PM
Received 1,334 Likes on 864 Posts
When I got my donor 93 running...it sputtered and wouldn't run well for a few minutes. I had to hold my foot to the floor for quite some time before it cleared up and ran decent. I then had to re-adjust the idle setting...was too low.
But yeah it sounds like the throttle index is off.
Old 08-09-2013, 07:52 PM
DOZENVALVE's Avatar
runs! all she needed was a slight tweak... now i can only sit an wonder if that throttle index is perfect on the money or if it needs more fine tuning. its very hard to only get 1 tooth because the splines on that shaft are so **** small.
Quick Reply: Manual hand pump will not prime fuel system for me
