Manifold to turbo stud
Does anyone know what thread and size the manifold studs are that go through the turbo? I was trying to put my exhaust housing on and the first one i tried to get the nut off it snapped the stud in the manifold. I guess this is a project that I will have to do at work cause I have a torch there. i was trying to do it at home and figured if I could not get the housing off I would just take the turbo with me and heat it up but it looks like thats not going to work.
^^^ What he ( Captain Chrysler ) said. ^^^
They are right at 1-1/2 American inches long.
I somehow came up shy one stud in my recent project, so I substituted a plain old bolt of the correct size until the next time that I order from McMaster-CARR.
The local ACE has a huge new cabinet full of every metric bolt imaginable; alas, they do not yet have studs.
When I removed all the turbo studs from my manifold, I soaked them with knocker-loose just about every day for a couple months.
Then, I layed the heat to the surrounding area with a plain old propane bottle torch.
Candle-stick in hand, as soon as the stud and surrounding area was about as hot as it was gonna get, I took away the flame and pressed the candle against the hot threads.
The melted wax penetrated deep within the threads and the studs walked out with ease.
I just happened to remember an old damaged one laying on the bench.
I went out to the shop and layed it on the ruler.
1-5/8 American inches long overall length.
3/8-inch long un-threaded portion.
Both threaded ends identical in length.
You will have to convert these numbers to communist numbers before ordering.
Thanks very much everyone I will probably just get a bolt for now. I will probably need to order a stud. No one around here will have it.
I've got two off my he351 if you want them, I think they're the same? just squirt some wd40 on them and let it sit for about 15 mins and get some vice grips and screw them out.
Crazy_Farmer
05-23-2010 06:05 PM
drewblood
08-19-2007 02:27 AM
74dart
07-07-2007 07:58 PM
Dusty Ratcliff
04-02-2006 11:08 PM
