Major Fuel Leak. What Do You Guys Think I Should Do?
I joined the forum about 3 weeks ago after I got my 1993 W250. It's a standard cab, factory 5spd truck. 272k. Bone stock, except for the fact that it rolls coal, which I think is because somebody tuned on the stock pump a bit. Today on the way home from work, a massive fuel leak sprank from somewhere on the injection pump. I cant tell exactly where it is coming from yet, but It is coming out QUICK.
I was told the stock VE pumps suck. So, Is it time to upgrade? what is my smartest move?
thanks guys
thanks guys
thanks Mark
I am no expert on the ve, but it seems that if it is gushing out, it may be a loose injector line or maybe the line from the fuel filter. Is it rusty? Is it shooting out under high pressure, possibly a loose or perforated injector line, or is it more of a flow, could be the line from the fuel filter. My only experience with a leaking pump was just a drip. Hopefully the ve experts will chime in...Mark
well on sunday im going to get in there and check it out. i just wanted to post now in case there was some kind of common pump failure that somebody may know about. ill chime back in sunday after i check it out and let you guys know what i find. until then i will take all the advice i can get from the pros here on DTR.
this is my 2 cents first off whoever told you that the "stock" ve sucks was not correct, stock those pumps do a good job tuned properly they can be like opening a can of whop butt ...I guess at this point my question would be is the leak coming from the top half or the bottem half ..
If by suck you mean it's reliable, gets great fuel mileage when tuned properly and can double the power your truck made stock for almost free then yeah they suck.
I'll give you five dollars for it.
Dry it off and clean it as best you can then have a buddy crank it and try to find where the wet spot starts.
hose the pump down with brak klen and wipe it dry with a nice clean rag ...repeat until clean ...the leak will show up pretty quick then
Received 1,648 Likes
Once you crank it over, it should tell you where it's coming from
BTW....
You should put your trucks info in your signature and let someone know where you live. Maybe you can hook up with another member, and figure out where it's coming from
Bad mojo telling everyone that you heard VE's suck. I guess you haven't read this thread, huh ?
https://www.dieseltruckresource.com/...e-t313287.html
His truck ROCKS, and it's a VE
Just to clear things up, I don't think VE's suck. I'm new to cummins diesels and don't know anything about them. My local diesel shop told me that he VE's are junk. Probably be auss he wanted me to pay him money to upgrade it. There is a current post on here title "who says a VE can't compete" and the guys truck is sick. Makes 900ft/lbs. I was simply stating what I was told.
I cleaned the pump today and had a friend fire the truck for me. FUEL is cascading down the back side of the pump where I can not see. I definately know it's not comi from the low pressure feed or the 6 high pressure injector lines. I can also tell for sure it is not coming for the seal between the pump and the pump top. I feel I need to remove the entire pump to find a bad spot.
I have been watching the old Chrysler videos on removing the pump and the only things I'm worried about are making sure I keep the pump in the right position with the engine so when I put it back in they are perfect as far as TDC and whatnot. I also need to get a t bar puller for the gear and a 13mm curved wrench. Everything else I am comfortable taking apart. I got a set of crosws feet wrenches today.
In the mean time I worked on my KDP mod. I got the new bolt and tab in today in about 3 or 4 hours. And now I just need To go get a timing cover gasket and put it back together. (Minus the oil filler tube so that I can remove the injector pump)
Also sounds like its time for a a 366 spring while all this is going on? I also had trouble locating one at genos garage. Not sure where the best place is to pick this up. I will probably remove the throttle stop as well. It seems there are no reprocussions to that mod.
That's how I would do it, except I'd use compressed air to clean up the mess.
BTW....
BTW....
You should probably leave the timing cover off until you remove the injector pump. It would be easy to put it on tdc, because you can see the marks. Also, if the woodruff key comes out, you will see it and be able to fish it out. I think all in all the job is pretty ez with the cover on, but is easier with the cover off. Also this is a good time to replace the front seal. I assume that you have the radiator out? Even easier..Mark
I still have the radiator in. There is quite a bit of room even with it in once you pull the fan. And yeah I will leave the cover off until I fix the pump. Obviously it will be easier. Do you have any idea what could be leaking in the backside of the pump? The only place I can't see?
