M&H dynamic timing???
OK so I was lookin around online for some new easy install goodies for Christmas n came across m&h dynamic timing advance, has anyone tried one out on there trucks?? Bang for Buck??
Unless it's untaxed, then it's red.
I run one its great. It's a ton of money for the amount of parts you get in a tiny plastic bag, but it makes power for sure. Do a thread search on Cummins forum there's a post like 7 pages long with great detail.
I run one but I have to take it off in the winter. Otherwise it works great. It effects my cold starts for some unknown reason. As far as i know, I'm the only one with this odd issue.
I'm glad I bought one. I wasn't really wanting to bump my static timing and lose my bottom-end but wanted to advance top-end. It works great!
You don't need to reset your timing if your only running a "little" advance. You should have no problem with 1/8". There are a few that are running the timing device even with a tooth bump. It all depends on your overall set up.
1st Generation Admin
This is quite true as I actually run my mess advanced two teeth with the M&H spacer. The IP & gear-case marks are right at each other.
What rpm, injector sizes are people running to warrant having the static timing bumped while using a dynamic timing spacer? I'm just guessing but wouldn't having the static timing bumped even an 1/8th " defeat the purpose of the M&H spacer?
I really need to measure where the timing is via the micrometer if only to be able to put it back there when I pull the IP this winter.
Understand the way my timing is set: With the KSB ON (full advance), I did a bunch of dyno-runs to dial it in for the most horse power at WOT.
That's where the IP's bolted down. The pump is two teeth advanced, and has the IP to gear-case marks VERY close to lining up (just a bit advanced, 1/16"ish?). It includes the dynamic timing advance thingy.
Back-off two teeth, and you're pretty-much where M&H wants you to run it.
But I do run 6x0.016" injectors too.
Not sure where I'm going with this .. .
I may very well be retarded timing wise in the stock running range (No KSB).
