Low pressure piston lift pump question
Old 03-09-2012, 09:01 AM
bryson711's Avatar
Im getting ready to do this swap, I have found 2 different pumps and im not sure which one to go with, the cummins pump part#4988751 is 186.61, and I found another one from Ofi that is part number hfp702 for 64.43. What is the difference between the the 2? I found both these part numbers from searching through the forum
Sent from my DROID2 using Tapatalk
Old 03-09-2012, 11:08 AM
jimbo486's Avatar
From what research I did before I went with the piston pump is that the Delphi HFP-702 actually runs under 10psi at idle, IIRC. The Cummins pump runs anywhere between 15-17psi at idle. I'd prefer (and I'm glad I went with Cummins instead of the cheaper pump) to have higher pressure knowing it'll take a little more to pull pressure down in a WOT run.
Old 03-09-2012, 11:25 AM
bryson711's Avatar
Interesting I figured there was some sort of reason that it was much cheaper, I think I will go with the extra money and get the good the cummins one. I just did not want to buy the expensive one if the cheap one was the same thing. Thanks for the help. But I guess if someone wanted to go the cheaper route the delphi would still probably be better than the stock lp
Old 03-09-2012, 11:31 AM
PapeCAT's Avatar
Diesel Auto Power sells the whole kit with the Delphi pump for 270. It is a rip off because of how cheap the Delphi pump is to buy stand alone! For that price I *assumed* that I'd be getting a carter/cummings pump. Silly me.
I priced out the cummins / carter at the local place here and it was over 250 now.
Old 03-09-2012, 11:49 AM
bryson711's Avatar
I was looking at that on diesel auto power. I did not realize it was the delphi pump that came with it. That's a big rip of, that pump is only 65 bucks on ofi website. And the rest of the cummins stuff is only about 55 bucks so you could do the whole thing for around 120 plus shipping. I just don't know if I trust that pump compared to the cummins pump
Old 03-09-2012, 12:21 PM
9812vram's Avatar
Originally Posted by PapeCAT
.....I'd be getting a carter/cummings pump. Silly me......
No "g" in Cummins bud!
Old 03-09-2012, 12:25 PM
jimbo486's Avatar
Actually, the specs on the Delphi pump put it close to the stock diaphragm lift pump. Stock pump is 3-5psi at idle and IIRC, the Delphi pump was around 4-7psi at idle. Not much of an upgrade if any at all. I prefer spending the extra just for genuine Cummins parts.
Old 03-09-2012, 12:36 PM
PapeCAT's Avatar
For stock I prefer the Delphi over all other lift pumps. Simply because you don't NEED the extra PSI and it is easy on the VE seals. And it has obvious advantages over the diapragm pump that can rip and spill fuel into the crank case.
BUT I don't prefer throwing 150 dollars in the trash with the Diesel Auto Power kit!
Old 03-09-2012, 12:37 PM
PapeCAT's Avatar
Originally Posted by 9812vram
No "g" in Cummings bud!
Thanks 9812vram. I'll take a note of that. Thanks for keeping us first genners in line on our board.
Old 03-09-2012, 12:38 PM
jimbo486's Avatar
True. If you're in a pinch and need a pump, the Delphi would suffice. For a nearly stock motor/VE, it'd work just fine in that sense too.
Old 03-09-2012, 12:39 PM
9812vram's Avatar
Sorry man, I love to read and learn on all the trucks, but I just HAD to tease ya!
Old 03-09-2012, 12:42 PM
PapeCAT's Avatar
Too funny!
Check this out:
https://www.dieseltruckresource.com/...light=cummings
Old 03-09-2012, 12:50 PM
9812vram's Avatar
Nice. PipeCat you jerk! Ok! I admit it! YOU GOT ME!! BAAAAHHHGGG!!!
Old 03-09-2012, 12:52 PM
PapeCAT's Avatar
You are a good man, 9812V.
Old 03-09-2012, 12:56 PM
9812vram's Avatar
Likewize! And thanks for the jabs. It's what makes this place awesome!
You can continue on with the thread... I'm done... lol
Quick Reply: Low pressure piston lift pump question
