low beams out, high beams work
While you are doing that, cycle the tilt steering up and down, in case you have a broken wire in the column, or a loose pin in the multifunction switch connector.
When I first got my truck, one of my high beams was out but the other worked. The problem was that the wire that goes to high beam on the light connector was broken away. Simply spliced it back in and it's still working 5 months later.
If you are referring to why am I still using Silver Stars?
Because I have checked and tried almost every H6054 lamp I could find and they are about the brightest legal headlamp on the market.
I was getting only about 6 months of life from them until I built a regulator to keep the drive voltage around 13 volts and picked up an additional 3 months without sacrificing a drastic decrease of total output in lumen's.
Most people would get better life from their lamps than I do because my relayed headlamps deliver full battery voltage 13+ volts AT the headlamp.
For the dramatic increase in output over regular halogen headlamps replacing the headlamps every 9 months is an acceptable trade off for me although I sure do complain when I have to replace them.
I am always on the lookout for a better brighter lamp but as of yet I have not found one, I want to try a pair of the Trucklite 5x7 composites with a pair of Silver Star Ultras but I first need to check to see if I like the cutoff pattern they produce. (notice the filament cap to prevent glare from the front of the lamp)
http://www.truck-lite.com/webapp/wcs...2507&langId=-1
Maybe in a few years I will see if I can get my hands on a pair of LED's maybe I can get someone to sponsor my truck if I put their name on the back of it.
My first choice,
http://www.truck-lite.com/webapp/wcs...Name=/home.jsp
http://www.truck-lite.com/wcsstore/t.../27450C_NP.pdf
These would be my second choice.
http://www.jwspeaker.com/other/led-headlamps
BTW incase you were wondering, the Trucklite LED's can be yours for around $225.00 each.
Also E-Codes are not leagal in the US, the optics are made for people who drive on the wrong side of the street.
Jim
My first choice,
Jim
Now my delay wipers are acting up.... might have to replace this Lucas thing anyway.
I've found that, as mentioned, the most common cause of these intermittent headlight failures is the dimmer (multifunction) switch. If you turn on the headlights and cycle the dimmer switch several times rapidly, you should be able to get it to act up a couple times and prove itself to be the problem.
Used your suggestion to cycle the tilt steering up and down and it worked. Low beams came on and the light around the ignition went out. THANK YOU!
Any suggestions on my next step? Testing and how to fix?
Idaho Guy
22
07-23-2014 11:48 AM
Tyeopalinski666
01-16-2014 03:59 PM
handymantim
16
07-30-2012 12:34 PM
vtec_vigor
21
06-06-2010 12:37 AM
mamm7215
19
06-04-2004 09:39 AM
