Lifting a 2wd
Lifting a 2wd
Has anyone lifted a 2wd cummins like mine in my sig, i want to go up 4-6" to get a little more clearence, how can i get that much lift, i know that the back will be easy but the front is what i don't know about,
I am pretty sure that the best you could hope to do is level out the front end. Unless you build something custom, there isn't much out there in the way of lifts. Check my sig for the easiest way to level yours. Worked great for mine.
There are also some coil spacers designed for our trucks on ebay for 49.99. I will look again and find the link. These go under the coils. Just type in D250 lift Item number: 120276605597
