lift pump inlet fitting
Hi, I'm about to change the leaky lift pump in my 93. I see there is some sort of strange assembly on the inlet side... plastic.
If I just back the fitting out of the pump, will it break something?
I looked at the sticky for changing the pump but none of the pictures work.
pls adv,
tks,
rjm
pls adv,
tks,
rjm
here's a link to the sticky where the pictures work
https://www.dieseltruckresource.com/...t+pump+fitting
I guess I'll just try pulling the fitting off, see what happens
tks,
rjm
tks,
rjm
1st Generation Admin
The fuel line from the tank simply plugs into that fitting. Just release the two tabs on either side of the hose fitting to remove it from the pump. Then unscrew the pump's fitting.
No weird science.
No weird science.
yes, I got it done...
I was just thinkng along the lines of the time it takes to not break something being well spent... especially something wierd looking
tks
rjm
tks
rjm
