Leece Neville Alternator
Old 08-30-2012, 06:42 PM
BILTIT's Avatar
Ya i can weld and have a welder etc. I just like stuff that bolts on lol.
I have many other projects that demand my attention so i like quick and easy.
Old 08-30-2012, 07:07 PM
j_martin's Avatar
Originally Posted by ClassA4x4
I used to be turned off by a lot of mods, until I bought a cheap welder and learned to weld. And for the past couple of years, Ive been using my TIG welder that costs less than $1000.
Anyway, the fab work to install a large alt in the cummins bay are really simple:
1. Cutting spacers for the hinge mount. That can be done with either a hack saw or with a $30 angle grinder/cutter, if you dont have one already
2. Small Scraps of 3/16 or 1/4 thick plate metal. That can be had from Lowes, home depot or the remnant bin of your local steel supply shop for free
3. Vise, for holding / bending stuff
4. Drill and bits
5. Welder, to be able to weld bracket pieces in place (i.e. The alternator in place, with the brackets bolted tight). The welding part just takes less than a minute for a couple of beads, but takes 10 minutes to set up.
And nowadays, if one couldnt weld, there are now mobile welders found in Craigslist who are willing to come to your home for a minimum hour for just $45.
You'd be amazed at the pretty welding you can do with a mig welder from Harbor Freight for under $200. Same welder will do flux core, which works better on old stuff. Just toss the wire they sell you and get Name brand material.
Old 08-30-2012, 08:06 PM
ClassA4x4's Avatar
Hey watch out, if I get motivated, I might put together a complete bolt-on bracket and spacer/shim set and if demand is good sell them online for $49.99. And then expand the line to other trucks and cars. Don't hold your breath though :-). The 28SI at only $225 I believe would be the safest, most inexpensive and hassle-free way to get a high-output alternator. Compare that to $449 from aftermarket builders.
Old 08-30-2012, 08:17 PM
ClassA4x4's Avatar
LOL, 8 years ago I started welding with a $75 HF flux-core welder and used it occasionally and productively for a couple of years until I developed an aversion to spatters :-) Now I carry a portable TIG 185 at the back of my motorhome generator compartment.
Old 08-30-2012, 08:23 PM
BILTIT's Avatar
I have a miller 180, does everything i need and then some. I would really like to get a TIG.
Old 08-30-2012, 10:55 PM
j_martin's Avatar
The flux core spatters quite a bit, but solid wire gas shielded, if it's set up right is very smooth.
I've run it dual shield for tight spots with good success also.
Jim Lane
09-11-2024 06:45 AM
apwatson50
10-28-2013 09:31 PM
5.9Excursion
03-13-2008 07:08 AM
Jim Lane
01-29-2007 07:18 PM
Ron
01-24-2005 09:29 AM
Quick Reply: Leece Neville Alternator
