Leaking Lift Pump
Guest
Posts: n/a
Leaking Lift Pump
I was just wondering....does the lift pump start leaking before it is about to go out (as in a water pump)? I just noticed that mine has started leaking and was wondering if it might be fixing to go. I just had a new injector pump installed and it has started leaking since then. I really started noticing it after I installed new fuel filter and manually pumped fuel to fill it (about 30?? pumps). <br><br>Thanks for any info....
