Leaking INJ. pump-fix on or off truck? pic inside...
Hi all, after installing the high volume/pressure lift transfer pump my injection pump started to leak pretty bad. I found the leak, but to my surprise the seal is a little different from what i would've thought.
The leak is comming from the throttle shaft that is circled in red in the photo. Do i need to remove the pump to get this redone, or can it be done on the truck?
Thanks
Brent
http://pg.photos.yahoo.com/ph/brent2...cd.jpg&.src=ph
Thanks
Brent
Do it on the truck, the dissasembly and reasembly is going to be the same as installing the 3200rpm governor spring.
Found here:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
And then you'll put a new o-ring and new throttle shaft bushing and possibly a new throttle shaft if its grooved really bad. But more than likely the o-ring and bushing should fix it.
Can't find part numbers sorry
You might be able to find them in a search, should be there somewhere, I had the same problem a while back.
Found here:
that pretty much says it. get the whole gasket kit from bosch...it's like 20 bucks. You may have to order the bushing separate, I can't remember, but the o-ring fixed a real bad leak on my buddies even though the bushing looked beat....
4969joes
03-28-2010 05:26 PM
9 sec camaro
20
08-26-2006 01:30 PM
