Larger Exhaust for the 1st Gen
Are there any good off the shelf larger then stock exhaust systems for the first Gens or will i have to have something built for it? Like 4" or something like that.
I am using a Stan's Headers 4" turbo back with a Donaldson straight through muffler. It uses all the stock hangers except for the tailpipe. A bracket is included with the kit that you weld where ever it is called for. I was told the reason for this is because of so many different variations in tailpipe bracket locations even with trucks of the same year. Rip Rook makes a nice exhaust also. However, the standard would be a 3" DP with 4" back. You can order it with a 4" DP but you will need to finish fabricating it; he is not jigged for a 4" DP. It doesn't include hangers either. My system was very easy to install. The most time consuming part was cutting off the old exhaust. It was rusted and wouldn't come apart at the joints. You AND your truck will be happier with an exhaust upgrade.
Originally Posted by Terraizer
Thanks for the Info guys, looks like the Stans Headers system will be the one i will go for.
I feel for you 1st geners when it comes to the exhaust on a 4x4... WOW.. is it ever tight around the transfer case... 4in is very tight... anyone done something with 5in... looks like the only way is out the hood.. lol.. or all the way below the frame....
Originally Posted by MMiller
Has anybody found a kit that has dual tail pipes? I kinda like sharing the smoke and sound with both sides of the street.
Michael
Michael
