Ksb?
OK, I'm from the old diesel school.
You retard timing for lowend power, advance timing for topend power.
with me so far, see where I'm going????
IF you were to use the electromagnetic solenoid which is fast acting, could
you not use the KSB for timing advance??
IF so, this would make for a killer setup. Hook the KSB to a toggle or micro switch
on the fuel peddle. Cruzin on advanced timing= better fuel milage, throttle response
and general performance. Flip the toggle and retard the timing when you need or
want the lowend power.
This is NOT a new idea to Cummins, they used it not too long ago on the NTC series
and called it "step timing" with this setup when you stepped on it the cam followers
were rotated a bit to retard the timing. I had this setup on a Big Cam NTC and with
the fuel cranked up this was unreal and with twin-turbos it would scream at 80,000
pounds. In the days when 425 Cats were top of the line the little 855 Cummins at 475HP
would just roll on bye-bye.
OK lets get this ball rolling and see if the shadetree mechanics can work this one out.
If anyone has a part number for the electromagnetic solenoid please post, I'll try anything ..... once.
KSB Problem
Hello Wanadiesel,
I have a question on my KSB. I have an '89 engine with a water IC. My KSB switch is open on cold start and closes applying 12V (14 when charging) when warm. Trouble is, nothing happens and she is a bugger to start even on a warm day. However, when I plug the block heater in overnight she starts instantly. Bad KSB? Looks like I can replace it myself; any gotchas I need to worry about?
1st Generation Admin
Wow! An older thread sticks its head up in the crowd!
WELCOME to our forums Jimmy.
The KSB just advances the lower range of the total dynamic timing range so as to help the cold engine run a little better till it's warmed some.
- How cold is it when it's giving you a fit?
- Are you using the charge-air preheaters (Wait to Start)?
- Are you running stock/OEM injection timing (any other mods)?
Hi David. Thanks for responding. It does not want to start unless it's a warm summer day. Acts like the fuel has drained back to the tank. However, when I plug in the block heater, starts almost instantly.
This engine is not in a Dodge, it's in an '85 Chevy Suburban. I do not have charge-air preheaters. I think the previous owner "turned the fuel screw up" whatever that means. I can't even find that screw on the pump.
I have phoned Cummins and they do not show the KSB valve as a separate item for sale. Recommended I go to Bosch.
Any help you can provide would be geatly appreciated.
Jim
Jim
Another question. Is there any way to set up this forum so that when I receive a reply to my post the forum sends an email to me notifying me that someone has sent me a reply?
Jim
Jim
