Knock when shutting off, and driving a certain way...
Old 10-08-2006 | 06:43 PM
gman07's Avatar
This truck has had a knock when shutting off for a while now (not just the "wet-dog shutdown"), and I recently noticed that it makes a growl/vibration when turning right, that is, when the weight is transfered to the left side. The knock is also only there when the truck is shut off with the passenger side uphill (again, with the weight on the left side). Last, but not least, with the truck on a sidehill, drivers side downhill, in drive, it also knocks and vibrates. The vibration is related to engine speed. Any ideas?
I might as well make this post about performance too I recently put the 18cm housing back on and got a decrease of 6psi boost, but no EGT drop. Was the extra 6psi really helping that much? Enough to overcome the restriction of the 12cm housing?
TIA
Old 10-08-2006 | 07:00 PM
flashgordon's Avatar
TIA
Check you tranny mount and the bolt that attach it.
Old 10-08-2006 | 07:22 PM
gman07's Avatar
Thanks. I was thinking mounts, I was just getting other opinions
Old 10-08-2006 | 07:27 PM
Mine would make some funny noise when it would gets down to -10* or colder just wrote it off the to cold.........when i rebuilt my t-case this summer, i found that one bolt had all but came out and a nether was loose
whating for cold weather to se if atleast one of those strange noise form frozen rubber mount go a way!
Old 10-08-2006 | 07:49 PM
Also check to see if the exhaust is hitting anything.
Old 10-08-2006 | 09:41 PM
spunbearing's Avatar
Good call. I also had a strange noise that took me forever to find. Turned out to be the sheet metal cover over the slave cylinder. It was cracked. Bruce
( mannwelder ) welded some washers over where the stress cracks were. He even gave it back to me sandblasted and painted. No more noise.
Old 10-09-2006 | 12:22 PM
Redleg's Avatar
Frame might be cracked under the steering gear if it's doing it when you turn.
Old 10-09-2006 | 08:18 PM
gman07's Avatar
Thanks for the suggestions guys. I still haven't gotten around to checking it (busy time with harvest and all). However, I recently put a new steering gear reinforcement plate on, and the frame there is fine, so that is one possibility ruled out.
Zee
03-23-2010 10:54 PM
Dean Snow
10-01-2007 04:00 AM
HappyGA
15
10-16-2006 09:21 AM
Hoss
30
10-03-2006 03:57 PM
lightening ram
01-20-2005 12:36 PM
