King pins
Or I might leave them out as I would need to hone it and it might be a size over. Now I need to go find some badges in the barn because some a$$hole stole mine.
I had to use a 12"cheater to break mine lose, and bent the pipe doing it. Other than that it's an easy job. It's the biggest allen wrench I have ever seen.
Well, both sides of my hubs on the front were hot... I could leave my hand on it for about ten seconds and it was too hot to touch. Something isn't right, did I roast the bearings?
Good chance you have the wheel bearings set too tight. I usually tighten them up then back off a quarter turn and then tighten to the closest pin hole on the lock ring, then install jam nut as tight as possible.
afoulk
26
01-17-2009 06:05 PM
19Fury69
12-21-2007 01:17 AM
joncevans
32
03-02-2007 11:42 AM
