KDP mod
KDP mod
Installed the part to block the dowel hole. Cant really say Im totally confident with it. I added additional blue threadlocker to the bolt, but has anyone ever had this style back off and rotate counterclockwise? If that happened it would hit the gear. Part of me thinks I could make one that would contour/be inset to the casting and wouldnt be able to rotate. Am I over thinking this?
I have gotten to where I just tapped the KDP into its home all the way then tap the bore hole with a punch and hammer lightly to score the bore surface so it will not slide out the now slightly smaller bore hole. I then clean up the area and proceed with life.
I do pull the few case bolts out that can be reached easily, clean them up and re torque them down with fresh red loc-tite.
Man that dude is thick. I just used a "tab" the same shape but way thinner metal. If it rotates around the gear would just chew it up & spit it out no trouble. I've even seen folks use like a coat hanger wire. Doesn't take much, just like the staking as discussed.
Have you already buttoned things up?
I recommend, pulling it, staking the hole and returning the KDP retainer, if possible.
That way the problem is solved without possibly making another one.
If the idea of it rotating around and into the gear, which I can see as a legitimate problem, keeps you up at night.
Staked the hole and made a tab. Much much happier!! Oliver, took your recommendation and red loctited all the bolts I could get to in there.. thanks for tip👍
oliver foster (02-21-2021)
