Kdp?
Old 09-07-2005, 10:14 AM
Boatnik's Avatar
Kdp?
I have read alot of the horror stories refering to the dreaded Killer Dowel Pin and now I am wondering.........Do the 1st gens. have this affliction?
Old 09-07-2005, 10:35 AM
csramsey640's Avatar
umhm..........
Old 09-07-2005, 01:31 PM
cethane's Avatar
How often does the kpd pop out on a 1st gen????? I have only heard of a few cases. When RickD did the kpd fix on my truck, my pin had moved out quite a bit.
Old 09-07-2005, 02:54 PM
Alec's Avatar
My pin was solid in there, but considering Wannadiesel did mine FOR FREE I am still glad to know that is one thing about which I do not have to worry!
Old 09-07-2005, 03:29 PM
A-Poc's Avatar
From what I've read it's not a BIG concern on the first gens because of the timing belt and gears if I remember right. On 2nd gens the gears are more in the way and what not. But yes they're there without a shadow of a doubt. I'd like to do mine but considering it'd be my first time in... I'd probably need a good weekend to do so.
Old 09-07-2005, 04:24 PM
It's not as common on 1st gens as 2nd gens, but it can happen.
Old 09-07-2005, 04:39 PM
CSAGrey1's Avatar
Your kidding right??
I bought this stupid thing thinking that they were bullet proof! NOw I am seeing that not only do they problems with the fuel ststem but with a dowel pin as well?? I have heard of this on the 1st gen as a local shop here offers a solution and advertizes in the papers in this area; but your saying it is even a bigger issue with the 2nd gen?? DANG< DANG< DANG!!!! What exactly is this and when is it prone to fail?? What happens if it fails?? "Killer" doesnt sound like it is a good thing!!! How do I fix this before it happens and what should I expect to pay?? Guess I should have done a little better research!!
Old 09-07-2005, 04:45 PM
https://www.dieseltruckresource.com/...ad.php?t=36809
Read that thread and the two threads it links you to. I think the NWBombers have a travelling jig, fixing it that way is no big deal.
Old 09-07-2005, 05:11 PM
A-Poc's Avatar
I know these trucks are considered tough but NOTHING is bullet proof and/or perfect. Sure there's the odd fault but there's some running 300K miles with their dowel pin still in tact and as for the fuel system... some are running 600hp+ on a VE pump. I see little to no fault in these trucks and even when there is it's not a large issue. Point being though... you're not likely to find a truck as tough as one of these. Definately a bang for the buck if you're looking for reliability
Old 09-07-2005, 08:39 PM
Mudcat's Avatar
CSAgrey1 no need to worry you have a 24 valve they do not suffer from KDP droppings. Now the lift pumps you do have that claim to fame.
Old 09-07-2005, 08:49 PM
gman07's Avatar
IIRC 24v's also have the problem up to 2001 (i think) model year. I think Dodge started phasing out the old style timing gearcase in 99, but there were a few newer ones with it too.
Old 09-08-2005, 06:04 PM
The newest truck I've seen the old gearcase in was a '99. If the build date is after 8/99 don't sweat it. I don't do '00 trucks any more.
Old 09-08-2005, 07:07 PM
ChrisLib's Avatar
Thumbs up
Wanna jigged my KDP before the truck was mine, I had an opportunity to "examine" his work when I replaced the front crank seal ...NOT...just kidding . Wanna did a superb job of fixing the pin, I had even removed the set screw just to be sure the pin was good and it was bottomed out in the bore but I gave it a good staking for good measure. If it were me I would`nt lose any sleep over it, just put it on the list of things to do if you ever have the front cover off.
Old 09-09-2005, 03:24 PM
Chris, whose truck did you buy?
Old 09-09-2005, 06:30 PM
ChrisLib's Avatar
A fella from your neck of the woods, screen name is dogoman (Bob), IIRC he hails from Gap.
Quick Reply: Kdp?
