K&N Air Filter
Old 02-17-2003 | 04:14 PM
Blowndodge's Avatar
K&N Air Filter
Decided to change oil and fuel filters today and check on the air filter. After changing to a K&N filter, 50k miles ago I noticed that the fins on the turbo are black! Not really oily black, just black like the top of pistons. They weren't that way when I installed the filter. They were shiny and looked surgically clean. This troubles me because I've heard of the K&N controversy before and have never noticed leakage before. The filter came ready to use right out of the box and said so. I installed a fram paper filter untill I get more feedback! Also, does anyone know how to clean the fins easily without damage or is the black on them nothing to worry about for now?
Old 02-17-2003 | 06:03 PM
Redleg's Avatar
Re:K&N Air Filter
When I took my old turbo out a couple weeks ago, everything was black too. Thought maybe it was soot getting by a seal? I was gonna drive it a week and see if the new one was getting dirty, I'll have a BHAF on standby. Using a stock replacement AFE now, in the factory air box. Maybe it sucked the oil off the element, but it seemed sooty when I wiped it off the air horn.
Old 02-17-2003 | 06:06 PM
Blowndodge's Avatar
Re:K&N Air Filter
That's exactly the term, "sooty". There's just no oily feel to it.
Old 02-17-2003 | 07:46 PM
TurboAZ's Avatar
Re:K&N Air Filter
I had a K &amp; N filter on my 92 for awhile. I know that alot of people use them but I went back to the Fleetguard paper filter. I looked at the turbo and it had a sooty look to it also. <br><br>I still get 21+ unloaded at highway speed and 16+ in town and change the filter 2X or more a year. Just feel better about it.<br><br>I don't care about the turbo whine, I want reliability plus I don't have to clean the filter and re-oil and worry about getting to much oil on the filter. Here in Aizona the dust can blow alot.<br><br>Jim<br>
Old 02-17-2003 | 09:32 PM
hdm48's Avatar
Re:K&N Air Filter
I too have noticed this. However, when I had my intercooler out doing some port work, I did a complete check on all internal components and found no evidence of dust,oil or other unwanted debris. It seems to be located at the compressor wheel only. After looking at a sample under a microscope i found it to be an oily residue most likely from the filter. But I make 34lbs of boost and that is a LOT of air being pulled through the filter. And I know that any oil saturated medium cannot hold excess oil when exposed to high CFM.<br> So I'm not too worried, if it gets too much build up I will just pull the compressor side off and clean the wheel.<br> I use K&amp;N filters on all my race toys and I have never had a failure due to FOD passing by the filter.<br><br> dave
Old 02-17-2003 | 11:13 PM
Holsteinman's Avatar
Re:K&N Air Filter
I do not know how many miles with the K&amp;N, because I just bought the truck in January, but my turbo is clean, clean, clean. I know some people over oil them and that is not good. Just my .02 worth.<br><br>Paul
Old 02-18-2003 | 04:50 PM
Redleg's Avatar
Re:K&N Air Filter
Mine went in right out of the box, haven't had it a year yet. When I found the soot, I thought maybe the exhaust got by a seal and was getting into the intake when my turbo gave. The turbo didn't come apart though, and was rebuilt.
Old 02-20-2003 | 09:54 AM
Bob Beauchaine's Avatar
Re:K&N Air Filter
I've run K&amp;N for almost 10 years with no adverse results and oil analysis that show that the K&amp;N is doing it's job. I too have noticed a slight oily build up and cleaned them with Q tips. I just switched to Old Smokeys BHAF mount with my K&amp;N and I am 2000 miles from my next oil change and analysis - I will report my results. I will then switch to a &quot;Green&quot; High Performance Air Filter and repeat the tests and results after the oil change after that.<br><br>I can tell you that my '93 smokes less runs cooler (Egt's) and responds quicker with Old Smokeys BHAF mount. It is however louder - this is easy to overcome with the volume control and some good CD&quot;s in theCD changer ;D ;D<br><br>If interested you can read more about &quot;Green&quot; Air Filters at www.greenfiltersusa.com<br><br>Bob
Old 02-20-2003 | 11:33 AM
Paul S.'s Avatar
Re:K&N Air Filter
not necessarily on the same subject, I saw some guy was offering a mandrel bent intake pipe with a K&amp;N on the end, I am wondering if any of you guys have that and if you can put a BHAF on instead of the Knarly&amp;Nuisance.<br>paul
49lambert
01-17-2011 04:53 PM
EverydayDiesel
22
06-03-2010 12:10 AM
Wildhog
13
08-04-2008 08:07 PM
herb
07-18-2008 08:25 AM
nfsommer
04-16-2007 09:21 PM
Quick Reply: K&N Air Filter
