Just trying to get another one on the road.
My leaning tower of power at Beech Bend, Bowling Green Kentucky at the 2007 Chrysler Classic. 198 screaming cubic inches. Stock cam heavily ported head, Hooker headers, 3:23 open rear. Almost "getting some air" under the front passenger tire.
oliver foster (12-18-2020)
Sweet! Mine was the Leaning Tower of Power 225. IF I cut the wheel hard to the left and floored it I could chirp the tire...
Rug, betcha wish you still had the Super Bee and 'Cuda huh.
Dan, you're gonna need a manicure dude!
Rug Tucker- That Duster photo stirs up some old memories!! That was my first car way back when. It was a 1975 225 auto, 4 wheel DRUM brakes and an AM radio. I remember taking the cylinder head off and taking just under 1/8" off in our big milling machine at the shop where I was apprenticing, porting the heads, changineg the timing etc. Had a lot more get up and go after. The thing I miss the most about it is that it was such a simple car to work on and the interior still looked like it came from the late sixties.
Rob
Rob
Rob
Rob
It has an M-1 Mopar Performance intake and a rebuilt Carter BBD 2bbl. I have scads of the BBD's and even some specific slant BBD's. Back in the day it was running 10.58's in the 1/8th @59mph.
Here is a few of the car. I hope to one day start working on it. It’s a great driver. I need to fix the heater and it needs body work. I have an 8 3/4 rear end. A machined block and crank and a new air gap for it. Just need to fill in the blanks for the motor.
Rug_Trucker (12-19-2020)
"poverty caps!" Love 'em. I have a '66 8 3/4 that I can toss in. Also an open 3:91 pig. I have a '92 roller cam 360 that is supposed to be sold. Where's the money?
The Duster needs to happen indoors.
Thanks for posting the A - body Mopar pictures boys!
You have a really crappy connection between the Negative Battery terminal and the ground. Those test lights only need about 1.5 volts to light up. Those type replacement battery terminals suck. Get some military style and put big ring lugs on your battery cables. Then you can use ring terminals for everything else.
Edwin
Edwin
What I have always done is remove one fuse at a time till the light goes out.. then trace that circuit down
Edwin
Edwin
also this truck has a wiring harness that is totally shot. I suck at the electrical part on these trucks. I know it has some fusable links that are blown but I haven’t started to track those down yet. My son should be here today to help me out.
Got the bed off yesterday
Swapped doors.
Not sure this is supposed to be there
Fuel neck gasket is shot
This is what I have to work with. Gonna try to get the brake lights working today.
More jacked up wiring
Any guesses.
and I think the sending unit is leaking
Rug_Trucker (12-29-2020)
