IP drive gear skiped a tooth?
Or a dab of Loctite.
The Lord loves me
After confirming without a doubt that the key was not in the keyway and the shaft is off by as much as indicated by the marks, I pulled off the pump, ready for my heart to sink to the deepest sorrow I'll ever have.
No doubt, the Lord loves me. I must have done many good things to His people. The key was sitting on the ledge down below the hole ready for me pick it with the magnet - I was happy to break my telescoping magnet just for it to fit through.
Not being overconfident, i'm not gonna tig weld the key into the shaft. But I will stuff enough rag in there, plus fill that cavity with grease, and dimple/bend the key to make it tight into the shaft slot. I'll do the necessary aligning of the keyways with the key, free fom fear the key will fall. Then I will make sure everything is right (final assembly) BEFORE i remove the rag.
Thank you guys for praying for me.
Well that's darn good news...glad it hadn't dropped down farther!
When I do mine I slather the area, shaft, Key, keyway and gear with bearing grease. I had the key come loose a couple times and the grease held it!
Dhorn33
12-04-2007 09:35 AM
silverbullet02
09-23-2005 04:09 PM
