intro and question: surging and even stalling
Old 09-04-2011, 10:43 PM
2wheeldually's Avatar
hello my name is john and i recently acquired a first gen dually - love it!
what a comparison to the intertrashionals!
during warmup if you actuate the throttle and let off it might die if it doesnt it surges. once a lil warmer it will surge 4,5 ,6 times after letting off the throttle and then will normalize. once fully warmed up while driving suddenly lettting off the acellerator suddenly it will die. sounds like air is entering the fuel system, but with mostly metal lines what are common entrance points on these engines as they age?
motor appears to be bone stock except for K&N
thank you for any help!
Old 09-04-2011, 10:55 PM
simplysmn's Avatar
First off welcome Second Throw that K&N filter as far as you can if you want the motor to last just put a good filter on it and iof nobody has said this also don't use fram filter's either there junk check your fuel lines I'm sure you will find the leak .
Old 09-04-2011, 11:51 PM
Received 1,334 Likes on 864 Posts
I agree...K&N or any oil soaked fabric filters are junk..IMO They let in far too much particulate matter. Just look at what the big rigs run... big paper element filters.
Anyway as for the surging and stumbling. It could be air. Generally the line from the tank to the lift pump, and corresponding fittings, seem to be the biggest culprits. You can have a friend charge you tank with about 10lbs air and then you can climb around and look for leaks. I've never done this but those who have say the leaks show themselves quite readily.
Old 02-13-2012, 03:31 AM
thank you both, not had any internet - sorry.
yes have pressurized the gas tank in the past - great trick. will investigate carefully and find leak. too much survival stuff been keepin me busy..
i am really hoping to find a blueprint for the electrical for my first gen dually...
oh, i was wondering what the static compression for these engines is and how much stock max boost can go up to?
ty!
john
Old 02-13-2012, 06:49 AM
cmann250's Avatar
Get a FSM (factory service manual). The print version is about $100 or the CD version is $35. It's the best $100 bucks i have spent on my truck. More wiring schematics than you will ever need
Old 02-13-2012, 11:20 AM
cougar's Avatar
Need more information about your truck. There are variations between years and how they are equipped that will help diagnostics.
And welcome on board.
Next to gauges, a factory service manual is the best money you will ever spend.
getpower
07-01-2014 09:53 AM
6BT12V
07-31-2012 05:11 PM
esde
02-07-2009 01:07 PM
whiskeyrichard
03-11-2008 10:31 PM
Avanteone
01-08-2005 06:53 PM
Quick Reply: intro and question: surging and even stalling
