Intercooled Injector Fuel Lines
I bought a truck with water contamination in the fuel which got past the ancient filter. I’m now in the process of getting the VE rebuilt and dealing with the lines. My lines seem to have some rust in them even after soaking them but I can only seem to find p pump lines, non intercooled lines, and overpriced used lines on eBay. My questions are…
Can I just use these beat up lines after soaking them in evaporust and brake cleaner? How risky is this?
Can’t I just use non intercooled lines? Will the fittings fit on my VE and injectors?
Thanks!
Thanks!
Intercooled and NON intercooled lines are very different as the intake horn is in a different place. They run over the motor in different places.
The P-pumped lines are !00% different as the P-pump lines all start in a line on the top of the pump , rather than a circle coming from behind the pump. They also us a different size "nut" on the ends on the lines.
I am pretty sure I have a good set of intercooled VE lines in my shop.
PM me if you like.
PM me if you like.
The following 3 users liked this post by oliver foster:
schamran
04-11-2011 09:10 PM
kennyblatz
04-29-2008 01:16 AM
chucktownsend5
16
02-15-2005 10:28 PM
