Installing Isspro pyrometer
So long as the tip is in the heat, but not touching the bottom, it should be okay.
The threaded hole in my manifold is 1/8NPT, while the thread on my probe is 1/4NPT.
I had to use a 1/8NPT nipple, with a 1/8 x 1/4 bell coupling adapter.
My pyro works fine with this set-up.
Mine is like dpuckett's. The probe is infinitely adjustable for depth, then you tighten the collar and it's locked in place. I'll take a pic of it later. I got mine from DieselManor.
Yup, mine has a ferrule and compression nut, and is (was) infinitely adjustable. Now that I have tightened it up on 3 different trucks, it is kinda stuck in place.
DP
DP
I installed my pyrometer,boost guage and an hx-35.Everything went well and everything works.Thanks for the info.Now it time to dig into the inj. pump.
rip 112
20
11-01-2008 06:30 PM
Shootist
03-04-2005 10:26 PM
kelley15
10-09-2004 04:46 PM
