Installed the Moog leveling spring on my 2wd (pics)
Location: Springtown Texas, the land of MILFs and Honeys
I finally got around to swapping my front coils for the 7226S coils. I think I paid right at 125 for them at the local parts store. It's an easy swap, no spring compressor needed.
The ride is much better than the stock springs before was.
It sits good now. I'm waiting to see how it looks when they sag into place though.
I did the same on my 89, the springs were so sagged the tires would rub when turing on a little bump and the bump stops were gone. They really bring the front end up.
Ride is a good bit better. I think since it's not bouncing off the rubber stops anymore, that the ride is smoother.
Looks good. I had mine done at Champion spring along with some other needed front end work 50k ago...they havent settled a bit. They put some r/v springs in....I ended up putting add a leafs in because the front end went from 2inches lower to 2 inches higher than the rear. Thats a slick ride you have there.
whitepowertruck
09-20-2013 02:39 PM
07CTD4x4
13
05-29-2007 09:20 AM
EricK
04-15-2005 04:34 PM
