Installed drive pressure gauge, got a few Q's
Hello, today I installed a 60psi pressure gauge to measure exhaust/drive pressure Installed to monitor the exhaust pressure that the VGT creates so I dont run into problems on the road.
How much pressure should I see under normal driving conditions?
What is the maximum safe exhaust pressure on a stock engine???
Thanks for any usefull input
Typically, you'll see anywhere from 1:1.5-2.0 (boost pressure:drive pressure) or 1.5 to 2 times the amount of boost pressure. An optimum ratio would be 1:1, of course.
hey-Hey!!!,
Now y'all have got me wondering what is going on with my heap. I would also like a minimum ov drive pressure...which leads me to this, one can measure it to atmosphere, or differential( subtracting the pressure due to the rest ov the exhaust ). The former is ov course a lot easier...
cheers,
Douglas
cheers,
Douglas
What is the safe limit with back pressure without 60# valve springs? Want to use the "exhaust brake" function of the VGT once it is on. Will get heavier springs when I get a chance.
I was watching my gauges today. During acceleration the back pressure will go up to about 17-18psi then the boost starts rising. Once the boost gets to 6psi the back pressure steadily drops down to 12-13psi and stays as boost keeps rising. Had 13psi drive and 20psi boost for a bit.
Cruising at 65mph the back pressure sits around 12-15 and boost at 4-9psi, and 6-750*f for the egt's.
Is 20psi of back pressure bad with stock springs??????
The_Head
06-30-2011 10:35 PM
mullishacrew
04-27-2008 04:54 PM
GoodoleBob
09-27-2006 11:37 PM
Spooler
02-12-2006 11:43 AM
PADZZ
29
03-31-2004 05:25 PM
