installed 366 and now now shutdown
installed 366 and now no shutdown
I installed the 366 spring in my pickup today. Took it out for a test drive and what a differance that made. The problem is when I got back I turned the key off and the pickup acted like it was going to shut down but then fired right back up. I had to manually shut it down. What did I screw up here?
Sounds like your fuel shutdown solenoid went bad. http://dieselvw.com/PumpSolenoid.htm
Turning over higher RPMs would lead to higher case pressures. Might have something to do with it. Just a thought. Probably not the case though. Mine hasn't failed. Shouldn't have said that. Let me knock on wood...
IMO they've got to be related. Is there A how to for replacing the shutdown solenoid? Looked but didn't come accross anything. I'll look it over more when I have time.
Location: A 5th dimension, beyond that which is known to man.
1 Post
yeah... take 2 wires off of it... un screw it. screw in the new one. attach the 2 wires again.... getting to its the hard part. i took off my throttle brackets. some people cut it. i think its 24 mm wrench too.
1 Post
they are just a piece of rubber that gets ripped and cant stop fuel flow, so the engine keeps running. ive never heard of one failing to open but it is a solenoid so im sure its possible.
