Injectors clogged or what??
Old 01-06-2009 | 06:41 PM
Well my dad and I (he payed for it) just bought a 93 w250 auto truck. DON'T ask about it becuase we don't know what were doing with it yet
But when it starts it white smokes for 10 seconds but runs perfect,nice smooth rattle and nice turbo whistle BUT it idles high. It "runs" ok i guess for a bone stock truck but lol its still slow. 175k miles on the truck
Would clogged up dirty stock injectors make it idle high in park??
Old 01-06-2009 | 06:44 PM
It is cold outside, a little white smoke is not uncommon. As long as it fires right up it's fine.
Old 01-06-2009 | 06:46 PM
Would about the high idle? its not a normal idle.
Old 01-06-2009 | 06:48 PM
Is it idling smooth or rough/loping?
Might just have sticking linkage holding the lever off the adjustment screw.
Old 01-06-2009 | 07:00 PM
archer39's Avatar
perhaps the previous owner adjusted it or the lock nut is not tight and allowed it to move out of adjustment.
Old 01-06-2009 | 07:05 PM
No lopey idle, it runs perfectly smooth, i actually think its the best running one ive ever heard ,
HOWEVER upon going outside and flooring it it "breaks up" at a quickWOT shot of the pedal sitting still but just a little breaking up but its noticeable by the exhaust pitch. I didnt even check the throttle cable adjustment.
I was thinking maybe the power screw is tweaked but it doesnt smoke and its slow.
Old 01-06-2009 | 09:02 PM
Look to see if the throttle lever touches the low idle screw at idle.
Breaks up at high RPM? Only with a cold engine or even when warmed up?
Old 01-06-2009 | 09:19 PM
I just went out there and did it again. i let it idle for about 5 minutes and it runs fine all the way up to WOT. sorry about that
it just idles so stinkin high!!! I can hook our factory tach up to it tomorrow and see what its idling at RPM wise.
On a 93 the dealer tach is just plug and play right?
The throttle lever touches the low idle screw at idle, i have no idea how we're going to get to that idle screw though . i can't remember how you did it.
Thanks,
- Brandon
Old 01-06-2009 | 09:29 PM
Yes, if you have a factory tach it will plug in.
See the sticky for pics of my bent wrench.
Old 01-06-2009 | 09:41 PM
Thanks Dave,
Old 01-06-2009 | 09:44 PM
Onemoparnut's Avatar
I looked in the sticky for the bent wrench and could not find it.
Old 01-07-2009 | 07:43 PM
There's a very good reason for that: 'cause it wasn't there. Sorry about that.
It's there now, though.
Old 01-07-2009 | 07:50 PM
Nice. thanks!!!!!! I was just fighting with that idle screw the other night.
Old 01-07-2009 | 09:24 PM
NO_SPRK's Avatar
the idle screw might have vibrated out. now i control my idle by linkage
hungabunga
21
04-11-2008 11:15 AM
hungabunga
04-09-2008 01:16 PM
EKUgrad
05-15-2005 07:08 AM
CaughtinmyGrill
04-18-2005 06:46 PM
mhuppertz
09-22-2004 10:07 PM
