Injectors for 240-250 hp
I would like to increase the hp on my truck to around 240-250 using only injectors. I know must of you guys on here have adjusted your pumps to get the hp I'm looking for and I know its free. Other than the 366 spring some day I really dont want to mess with the pump. What would be a good set of injectors to get the hp I'm looking for.
Thanks
Thanks
I've heard that turning up the fuel in the pump creates additional pressure within in the pump and shortens the life span. I've read alot of posts where people have had issues after messing with their pumps which I'd like to avoid. There are'nt very many people in the my area that know much about 1st gen's and I'm still in the early stages of learning. So I appreciate any help.
Crank up the fuel pump. It's free and so far after one year of running hard I haven't caused a failure yet. the dyno numbers im my sig are at the ground thru a stock torque converter and automatic. The estimated flywheel horse power is 235 to 240.
Originally Posted by 1st gen Hobie
What are the biggest(most torque) you can run on a 1st gen? Thinking about sellin my POD's if I can gain a lot.
Originally Posted by Mike T.
Thanks everyone for the suggestions and info.
I was vary skeered to touch my pump . but after reading ablout all the mods I pick one and read it again will i was doing it. thay really aren't that difficolt......the ones that i have done, that is
Removing the cover under the star wheel and just turning it a 1/2 turn down will make it spool quicker or menny of the ether modes out there!
if you just wont to do inj ,then go for it, but if you want some free power then dont be afraid! ivan if you do mess up (witch you won;t if you fallow the tec face at the top(sticky!)
There is plenty of grate guys on this form that can anwer any question before, durning, or after the mods!
Just study the instruct and and do it!
Once you have it opened up, the instruction will make more sence!
I realy thing the only mod that would drasticley short'n your pumps life spand would be if the pop pressures were ingreast witch isn't evan the tec factes!
don't do it with out guages but As long as you have a pyro and a boost guage! Go for it!
Thanks
Thanks
You can look at it another way, too. Changing to a stiff torque converter will couple quite a few more horsepower to the road at the low end. A valve body mod will keep the bands and internals in check and prevent slipping. Then a good trans cooler to get rid of the remaining heat and you can add HP till the cows come home.
Regards, DBF
