injector pop off question
So i found some 215 hp p pump injectors (i'm just swapping tips) i'm going to throw in my truck and see if that helps it run better, I think i have a bad injector or delivery valve. I had my cousin check with a diesel shop on extrude honing some injectors for me and they told me i shouldn't do it and i'd be better off with new 60 hp injectors (still trying to find out hole count and size) and they told me i'd probably have problems with the 215 nozzles but i could try them, then they told me to bump the pop pressure to 260-270 bar and i'd be better off...My problem is A. I was thinking 260 bar would be pushing it (about 200 psi different) now if i bumped it to 265-270 I think i would destroy my injection pump. any reason to bump my pop pressure past stock pressure? whats a safe pop off pressure?
generally the VE shouldn't get higher BAR injectors, people do run PODs which are 260BAR I think, but I wouldn't even wanna go that high. It's hard on the IP. one Barrel supplies 6 injectors with fuel on a VE and the reason ppumpers can get away with higher POP pressures is because it has 1 barrel per injector. At least that's the reason why our local bosch shop says the VE shouldn't get much higher POP pressures. And I've read that same answer over on CF too.
Swap the 215 pump tips and have it set to 245BAR and call it a day.
Rick, I've read it both ways on cf lol, i've done some extensive searching over there, thats what has me confused some say its going to ruin the pump at 260 then someone will say pods are 260, then i've read where some say its an urban myth..... 1slowve I've had them apart cleaned the nozzles (used small brass wire from a tooth brush wire brush) blew them out with brake clean really good and looked the needles over didn't see much, what else should i look for, i didn't see any cracks or anything. I'll pop test them once i get them on my bodies to make sure they spray good.
yeah, take it for a grain of salt, but a local shop told me the same thing. And they know these pumps well, and do good work too. the guy who said it to me has been working on these pumps since the 80s and I trust his judgement.
It makes sense that the VE can't handle too much higher pop pressures though. And it's really common for ppump trucks to run in upwards of 300-310 BAR so I don't think it's an issue for them. I wouldn't wanna go any higher than 260 on a VE. I mean, guys have run PODs with success so it can't be too bad. It might shorten the life of the pump some, who knows. Nothing is confirmed, that's for sure.
The stockers are 500 psi low, the 2nd gen ones have 120k miles on them so hopefully the springs have seated in and the pop pressures will be a tad under 260 bar. So I maybe good anyways if I'm lucky.
yes, but he's never put enough time on a motor to even come close to saying how it affects long term reliability.
I never said it hasn't been done. I'm just saying (what I consider a reliable source) i heard it will shorten the life of the pump/it's hard on the pump
Looking back on that, it makes me wonder if they really knew what they were doing or not. The guys were really cool though, letting me walk through their test areas and watch my injectors get tested right before my eyes. It's the only shop that I know of near my area though so I don't know that I have any other choice but to got to them.
I've heard that as well and I agree entirely. Jeremy also has a 14mm pump as opposed to a 12mm. I'd assume a pump with more volume could handle a set of injectors with slightly higher pop pressures. However, I can understand a higher pop pressure putting an additional strain on a 12mm pump and therefore the possibility of a decreased life-span. When I had my stockers tested and then new 4x.014 nozzles put on them, the shop brought up the pop pressure and recommended 260bar. I said I'd prefer 245bar as the bodies call for (they should have known that had they looked at the bodies). Not knowing much at the time, I was on the phone with them numerous times discussing pop pressure. They kept telling me that they thought 245bar was too low. So I said, fine, set them at 250bar then.
