Inj. pump questions
Inj. pump questions
Can the smoke screw be ran in to far? I got to looking at my pump today to do the turn ups and someone had already bottomed it out where its flush with the nut. I ran the fuel screw all the way in and it never offered to run away, just had idle to high to adjust out so I backed it up 1/2 turn,turned fuel pin and bumped timing 1/8 inch or so. I'm still not sure if all this helped a whole lot though, this is a 92 with 18 cm/2 housing, stock injectors, swiss cheese air box, magna flow 3" muffler and all I'm getting on boost is around 23 @ wot with auto in od. Still waiting on pyro to get here so I can't tell temps yet. I'm wondering how loose my torque converter is? It was replaced just before I bought the truck along with a reman trans less than 20K ago by Quic transmissions in Albuquerque, Nm. and bill says it has a hd converter and hd planetary kit in it. Any idea if this might be hurting me? I pull an 8 1/2 x 22 enclosed racecar trailer that with the car and junk inside only weights 6000-7000 lbs. I know it catches alot of air but it just seems like the truck should pull it way better than it does. Any ideas? Thanks ahead of time, Terry.
Hi, no was talking about the smoke screw, was just afraid it would lock up the fuel pin being ran in that far, What about an h1e center and compressor with my h1c exhaust wheel and housing? Seeing alot of the h1e's cheap and they are suppose to be the older version of an hx40.
9 sec camaro
20
08-26-2006 01:30 PM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
