important fuel pressure question
Old 11-19-2008, 09:03 PM
thumbs's Avatar
Yeah bouncin back from mechanical to electric. Stay focused now remember rotor rotor rotor.
Old 11-19-2008, 11:38 PM
Philip's Avatar
what kind of pressure should I be seeing before the injection pump
I see 9 PSI on the filter inlet. 7 PSI on the filter outlet. There is a 2 PSI drop threw our filter/heater assy's.
Old 11-20-2008, 09:52 AM
thumbs's Avatar
Sounds like the way to go is two sending units one before and one after the filter connected to the same gauge. Anyone have a photo of this setup? That being the case the electric may be the way to go for simplicity. Is this over kill?
Still lookin for a 0-15 or 0-10 psi 270* fuel pressure gauge. Anyone know of one? At a reasonable price of course.
Old 11-20-2008, 10:26 AM
Philip's Avatar
Step into the 30 PSI gages. If you ever upgrade to the low pressure piston lift pump it would be maxed out. Most mechanical gages seem to live longest when they are working in the middle of their pressure range.
Old 11-20-2008, 10:34 AM
thumbs's Avatar
I've been lookin for a gauge with a good deflection but can't really find one. I am thinkin of an electric with a switch to before and after the filter. I want to be able to read a couple of # difference.
What are you usin?
Old 11-20-2008, 10:51 AM
BearKiller's Avatar
You can't get much more reasonable than this :
http://surpluscenter.com/item.asp?UI...atname=engines
They also have a 0-16-PSI Stewart-Warner for about thirteen-bucks; I have had one on one of my trucks for a couple years.
Old 11-20-2008, 04:04 PM
thumbs's Avatar
Yeah that's pretty cheap for sure. I don't have to go that cheap but didn't want to spend 200 bucks for one. I see a SW 0-15 2 1/16" 270* sweep gauge but it's mechanical. Do you know if they make one in an electric? I am thinkin now about the two sender setup?
Old 11-20-2008, 05:07 PM
You don't need a pre-filter gauge. If the pressure after the filter drops, change the filter. If that doesn't fix the fuel pressure problem, then the lift pump is bad. The chance that you might replace a fuel filter when the lift pump is the problem is a silly reason to buy a sending unit.
Old 11-20-2008, 09:07 PM
thumbs's Avatar
Hi Dave
Ok one it is. LOL Sometimes I can get carried away. Your right it would be a bit of over kill.
Can the tapped banjo bolt be obtained locally or is it mail order only?
Old 11-20-2008, 10:26 PM
BearKiller's Avatar
Here is the one you want :
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
Old 11-21-2008, 01:37 AM
dodgethis91cmns's Avatar
gary thats the banjo i bought for the 17mm i showed u by the fuel filter
Old 11-22-2008, 02:45 PM
got my gauge installed today, not to hard. reading 6psi at idle and running around at 25 crusing 5psi 45mph 4psi. do these numbers sound about right? or are they a little low?
Old 11-22-2008, 03:50 PM
https://www.dieseltruckresource.com/...6&postcount=14
Old 11-23-2008, 02:12 PM
thumbs's Avatar
Picked up an electric Stewart Warner fuel pressure gauge today. Anyway need a mounting cup for it. Are these things universal fit for a 2 1/16 or do I have to get one from SW?
thanks
Old 11-23-2008, 02:24 PM
BearKiller's Avatar
thanks
So far, every 2- or 2-1/16 gauge I have dealt with all fit the same hole.
Quick Reply: important fuel pressure question
