I'm tired of removing the air intake to change the oil filter!
Seriously!
One of the things I value about the Cummins engine design is that oil doesn't spill everywhere when I change the oil filter (Why can't EVERY engine manufacturer figure out how to do this!). So, in order to get the filter out of it's cubby without turning it over and spilling oil, I have to remove the air intake hose. I have a BHAF with 4" aluminum tubing and 2 45* rubber elbows, so removing it isn't as easy as a stock hose. Does anyone have a solution to this problem?
I have plans for the future to relocate the transmission heat exchanger. I hope that will help this problem. The coolant lines effectively make a little cage around the bottom of the filter that necessitates tipping the filter to get it out if you don't remove the intake. By relocating the heat exchanger I think I can do away with the coolant lines that make the cage.
Oh, well. If this is my only issue right now I guess I'm happy!
Amsoil dual bypass behind the bumper fixes that for me! Twins made changing the oil 'cleanly' a PITA!!
In combination with genos quick drain plug I can have filters and oil changed FAST!! and not a drop on the floor!
I agree, removing the intake-tube is a pain; but, being forced to take loose the intake-tube at each oil-change gives one more reason to take out and inspect the air-filter, which could otherwise be forgotten.
Someone on here enlightened me with the wonderful idea of loosening the filter, then slipping a bread bag over the filter before spinning it off; the bread bag keeps most of the mess contained, should a mishap occur.
Remote oil-filter mounting is on my list of future improvements.
I will second the oil drain valves, Fumoto ??F-104---I THINK??.
I wish I had known of them YEARS ago.
I have them on three of our Cummins trucks and am in the process of installing on the others when the oil gets changed.
I also intend to put them on the Getrags.
The one on my personal truck has been on there through numerous oil-changes and made a believer out of me.
The breadbag is a great idea. I have been so caught up in hating having to pull the intake tube, that I never thought of that!
I can't (or won't) pull my airfilter since it's a BHAF with an Old Smokey mount. I have a filter minder on the tube though like the 2nd gens have.
The problem I have going the other direction, putting the new filter on, is that I fill the new filter with oil before I screw it on. But I will try the breadbag solution next time for sure.
Someone please explain this "dual bypass" business to me.
I understand a remote filter relocater that simply functions like the original filter; but, what does this dual bypass do ??
Is one filter the plain old filter and the other a super-fine bypass filter, or what ??
Does this do the same job as the John Wayne toilet-paper filters ??
Thanks.
You've got it.
It's technically called a Dual Remote Bypass System. It's a remote filter kit with a 2nd bypass filter built into it. The bypass filter is super-fine. I was just doing some reading about extended drain intervals. The lab claims that if you run a bypass, and use regular oil analysis, you can have drain intervals up to 1,000,000 miles! This was on a class 8 semi. But still! The claim, and I think I'm a believer, is that oil doesn't "wear out." It just builds up contaminants that are abrasive to the engine. The fine filtering bypass filter is able to take these contaminants out. You change the full flow filter at a regular schedule, and change the bypass filter every other filter change. Oil is drained at a time when analysis says it's time.
Here's a link to the AmsOil bypass systems: http://www.amsoil.com/storefront/bf.aspx
The dual remote is the BMK23.
And yes, the "John Wayne Toilet Paper" filter is a bypass filter. Some people swear by these units. I've not had any experience with them. The brand name is Franz. Here's the website: http://www.wefilterit.com/
You've got it.
Thank you, kind sir.
I don't pull the filter until the oil is drained out of the pan. After the filter sits for a bit it dosen't dribble oil everywhere when you remove it.
