IM STUMPED and in need of more fuel
Old 10-13-2008, 07:49 PM
1985cucv's Avatar
Guys i am stumped i got a new converter and have a good valve body in my th400 The truck loads up more now but is only getting 1200 egts with all the mods i have. I have the stock Non intercooled injectors which are from waht i hear good for 300 horse,The power screw is maxed i have full travel with a properly indexed pump and i have gone over the truck again and again. I will be getting an intercooler eventually and fuel mileage is really not an issue but i dont really want pods. is there any better way to get more power for a decent price. Opinions on injectors would definitly help. Maybe i have more timing than i need but it only looks like 1/8th of an inch past the mark. i want more than what i have right now. I think a set of sticks would be promising
Old 10-13-2008, 07:54 PM
C/PRD/'s Avatar
There was a guy here that had some 4X.018" 's cut and said they pull extremely hard. I think that most guys can get alot out of rebuilding and EDM'ing thier stock injectors. But you could get some adapters and a set of 435's and be just as happy I'm sure.
Old 10-13-2008, 08:00 PM
366 Spring Chicken
Richie O's Avatar
Something must be wrong. I have a powerstoke intercooler, suber b s300, 4 inch stans exhaust, k&n filter and with my stock non i/c sticks I can hit 1500 easy. I have my stock converter in my 727. Pods won't do much over the stock non i/c sticks and will lower mpg.
Old 10-13-2008, 08:02 PM
big stinky's Avatar
I think a fuel pressure guage would be a good investment. Make sure your delivery is up to par.
Old 10-13-2008, 08:36 PM
archer39's Avatar
have you tried switching out your pyro for another one to make sure it is reading right? Like stated above get a fuel pressure gauge too. with the fuel you have you should be getting hotter than 1200 degrees with just the gillette upgrade.
Old 10-14-2008, 10:56 AM
DodgeFreak's Avatar
Wheres the probe also??
Old 10-14-2008, 11:29 AM
apwatson50's Avatar
Did you take the lock collar off of the power screw?
You might need to weld an 1/8" extension to the end of the power screw.
Old 10-14-2008, 01:29 PM
bgilbert's Avatar
That's what I was thinking, your egt probe. An intercooler will give you quite a bit more power. Forget about 300hp without one.
Old 10-14-2008, 06:44 PM
1985cucv's Avatar
Probe is in the manifold pre turbo i will check my fuel pressure i have a nice auto meter mechanical gauge that isnt hooked up yet. I dont really want to pipe fuel into the cab but if i have to so be it for the time being. where would i hook the gauge up to? i believ it is a 1/8npt female fitting. the fuel filter has less than 1000 miles on it. Could my fuel lines be to small? Also i have the 18.5 cm exhaust housing could that be part of the culprit? thanks guys for the input
Old 10-14-2008, 06:45 PM
1985cucv's Avatar
Power screw is maxxed out like half turn from runaway i knnow this because it ran away on me!!!!!!!!!!!! wide open throttle kinda crazy lock collar is off
Old 10-14-2008, 08:24 PM
big stinky's Avatar
What Im thinkin is your lift pump aint pushin the fuel. 1200 seems pretty cool for maxed fuel on non i/c injectors.
Does it smoke when the boost is up and your on it?
I dont think the 18cm housing is hurting you with the auto.
How much boost does it make?
Old 10-15-2008, 12:06 AM
tcs 91's Avatar
i put an air dog 100 on with a water/air intercooler at the same time before redding in june. the truck really ran better. the injectors really got happy but the egts went up such that i think if i hadn't put the intercooler on i wouldn't be able to drive it. you prob need 15# of fuel to the pump reliably. it would make a big dif. elec. pump also gives you a reliable shut down. mine won't siphon with the pump off. my experience only. tc.
Old 10-15-2008, 07:08 PM
1985cucv's Avatar
would the piston lift pump be sufficient?
Old 10-15-2008, 08:50 PM
loch's Avatar
Bgibert yes you can get 300, you can even get 390. Second not all pumps respond to full fuel tuning, some just cant supply more fuel.
Old 10-16-2008, 06:50 AM
bgilbert's Avatar
I always speak of fuel only. Fuel only in my world.
Quick Reply: IM STUMPED and in need of more fuel
