Ignition switch replacement
Is there a video or post on how to change out the ignition switch? I didn't see one in the sticky and one link I found was dead. Does the steering wheel need to be pulled? Will the new switch have a new key?
The service manual will have step by step instructions for replacing it.
The lock cylinder itself is a whole 'nuther story.
If you have a tilt wheel the switch is behind the key. If you don't the switch is mounted down on the column and operated with a rod from the key. This sticky might help with the Tilt wheel R&R.
https://www.dieseltruckresource.com/...-light-210156/
Edwin
Edwin
bobinyelm
10-15-2012 08:38 AM
