If you want to increase your MPG!
Put a new tranny in! 600 mile road trip this last weekend and my mileage increased 4 MPG! went from 17-20 to 20s and up! Maybe the lower stall speed TC or new internals or both,who knows, but NOTHING ELSE was changed and major increase
Does your truck have a lockup torque converter? I've heard on the interweb (but have never seen) that some late 93s had lockup. If not what torque converter did you install?
I'm going to be doing a lockup conversion on the cheap to my 518 here in a couple weeks. The cost of a 47RH either rebuilt or used is just too expensive for what I want to do so we'll see how it works out. Stay tuned, I'll start a new thread with plenty of pics.
I didn't do a lockup (I thought you couldn't on the diesels). But put in a precision with a lower stall speed, so it feels MUCH closer to a lockup. So far so good.
I'm just going to put out the steps to convert the trans cheaply with only 2 or 3 parts, except of course for the converter, as an alternative to the very expensive 47RH. My goal is to get as close to 30 MPG as I can just driving normally.
Good luck with yours I'm glad that worked out for you.
When I had my transmission rebuilt with a custom low stall converter, I only got another mile per gallon. 17-19mpg vs 16-18.
I wasn't sure if I was seeing things at first. Typically it's a good day when I get 128 miles at the 3/4 full tank mark and it went over 170. Stopped to top it off and over 20MPG. Checked it again on the way home and same thing! I feel like I'm driving a Prius or something
With the G56 installed I went back up to solid 19 MPG.
Hey KRB,
It's a precision and the stall speed is 1700-2000 (according to tech). On THAT note, I now seem to have the issue described here: https://www.dieseltruckresource.com/...t=Early+shifts where the 2-3 shift is too early and not adjustable with the TV cable. Tried to have the tech make adjustment and after 1 wk delay and a hearty "She's all set!" I discovered they didn't do a thing except jiggle the TV adjustment . Sooooo this "green spring" that's referred to (or the drilling out of the hole on the plunger) seems to solve the issue? I DO NOT want to take it back to Joey big talker and would like to tackle it on my next fluid change. Does anyone have pics or more info on this Transgo early shift modification?
Thanks in advance
Thanks in advance
Hey KRB,
Thanks in advance
Thanks in advance
RIPOIL
09-07-2006 01:42 PM
jthorpe
31
08-06-2006 01:39 PM
Hawg Lip
15
11-13-2005 09:56 PM
