I struck a new idea on how to make a smoke switch for our trucks!
It's his 6th post. Just the new guy on the playground and he hasn't learned how to play nice. He'll learn. An Admin will let him know quickly enough how personal attacks are dealt with.
wow dude, definitely not tolerated here. if you read the entire post, he did state that it was just a thought and it wasn't anything set in stone. if he really wanted to do that to his truck, then let him. you do what you wanna do with your truck and let us do what we wanna do with ours. he's just asking for opinions. a comment like the one you left is just disrespectful to all of us. dave will find you. who's the idiot now?
I don't particularly want MY truck to smoke at all, but it's a personal preference, just as the OP's preference was to make his truck smoke. While you may not agree with someone, we're all entitled to our opinions here.
Calling another member of DTR 'stupid' or an 'idiot' is considered a personal attack and is a good way to get yourself banned from the board.
chaikwa.
chaikwa.
I know it's an old post, but someone i know has a first gen, and he drained his windshield washer resevoir, filled it with diesel fuel, and ran the lines to an injector that was threaded into the PO's egt probe bung in the downpipe. It was insane. could only use it for short periods or it would cause accidents. the exhuast had to be hot as well, but not sure how much. it would just blow white otherwise. I think later he robbed a windshield washer resevoir/pump and put a switch in the cab so he could wash his windows.
What your doing is basically what the drive pressure style wastegate actuator does, but your spring isnt strong enough so its just blowing the waste gate open. You could make the lever arm longer, or get a stronger spring to control boost this way.
They sell them for 100 and some bucks, but, you could do your own r&d and save yourself the 100 bucks...
You could do a 2.5" Exhaust cutout, Or whatever size your intercooler piping is, An exhaust cutout is like a "Y"
So instead of the boost being made and being stopped by wall, it would just be blown out the open cutout into the engine bay.
Make it electric so when its closed you can have normal air flow through your intake and when you hit the switch it opens the cutout and the boost does not go into the engine.
me and Smokems did this on his truck except without the cutout deal. LOL
We just unhooked his intercooled piping where it meets the intake and let the boost blow out into the engine bay. can you say smoke???
I'm a msPaint pro so here you go-
1 Post
One thing i learned was from an airplane mechanic, was because i leaned on the intake panel of the plane. He told me that if you cut off the air flow and create a vacuum you'll cause the turbine(or turbo in this case) to go from 100kRPM to around 500k in a split second and ruin it almost instantly, so i don't think the before the turbo idea is too good based on this...and should be kept for runaway scenarios.
I personally like brandon and Smokems idea, its kind of like a blow off valve but manually activated.
Don't the grand nationals (and rice burners)do this to get the turbo spooled up on the line? then hit a switch along with their trans break and away they go!
I have thought about putting an air shut off just in front of the turbo as a runaway shutdown though I never thought of using it to make extra smoke. I could see it being hard on the turbo.
I like to offset the carbon footprint of hybrids and fill late model F-bodys with a little black smoke when the moment is right so I can understand the want for a little more smoke sometimes.
1 Post
The funnies thing about this whole smoke deal is that its more environmentally friendly than a gas car ever could be. No list of noxious fumes that eat away the ozone. Mostly just soot that cools and falls back to the ground, or gets electrolyzed(like static cling, the back of all box trucks) and sticks to the back of your rig.
Plus if you were to over speed the turbo, you would make a lot of boost. And little if any smoke.
